Wondering how i go about adjusting my handbrake in R33. At the moment I'm having to give it a full erection to apply the brake and even then its not as tight as i'd like which kinda gets annoying.
I've had a bit of a look under there and its a bit different to other cars I've adjusted it on (which usually have a Y wire type arrangement). It looks kinda like
(ignore the dots, they're just spacers to get the diagram ok)
Now where those wiggle things are it looks a bit like a small adjuster screw. Couldn't find my adjustable wrench (don't u hate that!) when i got under there, but can I screw these in or out to adjust the tauntness ?? Or I notice that each goes off to each wheel with a bit of a bolt there - or do i adjust it there??
Thanks
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/
extremely easy mate. After you take off the boot, you will see a bolt with a nut on it on the pass side of the hand brake. Just keep tightening the bolt till its right. Some people have found that when they tighten it, the bolt comes too far forward and rubs on their hand brake boot, so you may want to cut the end of with a hack saw.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-118794
A Hacksaw,,,,PLEASE,,,,this is a Nissan we are talking about,,,,put away the hacksaw for ever.
1/ Remove your back wheels
2/ There is a rubber plug on the rear discs that hides the ADJUSTERS,,,,much like a drum brake rear end on an older car,,,but it's on the front face of the disc,,,,spin the disc around till you find the adjuster,,,using a torch helps....
3/ You need a lever of sorts to click the adjuster around,,,.
If you are in any doubt,,remove your discs and have a look,,,,.
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-118968
Are you talking about inside of the car or outside of the car?
I actually have the centre console out at the moment 'cause i've been playing with it.. If its inside the car then all the better...then i don't have to climb under the car again (its kinda hard with just a jack!)
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-118969
Thanx ndr...so its at the wheels. Ok, i'll whip them off soon and take a look. I did have a look from behind and saw where the cable went to behind the discs.
Its different to my old R31 but thats not surprising. With the R31 i did it mid-body underneath there was like a double screw thingo.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-118973
Will you have the Console out,,,,,Back off the adjuster at the Lever a little bit,,,,Leave about 10mm to 15mm of thread showing,,,The Lever ones just to take up the slack,,,,.You can play with it later....
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-118977
Yep,,,exactly,,,,JUST and I mean JUST touching while spinning the disc,,,you should be able to adjust them with the discs on though,,,,or did I mis-interpret you. After you got that done,,,go to the handbrake lever and just adjust it about a 1/4 of a turn and then lock it up. This will even out the play in the cables.....
Joel,,,how easy is it hey,,,.
Predator666,,,,how did you go???.
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-121056
  • 4 months later...
  • 4 weeks later...
yer, this still doesn't make heaps of sense to me as i can't recall any sort of rubber access panel on the disc when i check the other day. i'll check again soon
predator666,,,when you remove a rear wheel,,,you will see 5 wheel studs,,,2 threaded holes and 1 slightly larger hole which should have a rubber plug in it. The rubber plug one is to do your adjusting. The 2 threaded holes are so you can remove the disc,,,BUT ONLY ever using High-Tensile bolts as a puller just in case it's a bastard to get off. Take a disc off and have a look,,,you will understand then what I'm saying.
Yes Moschops the inside of the disc has a braking surface and has Drum brake like pads in there and yes sooner or later they will need replacing.
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-375438
  • 11 months later...
Digging up an old thread, but is this the same for my 32 GTR?
Ronin are you physic or something. I just walked in after adjusting my handbrake for this weekends motorkhana at Oran Park. I would think that an R32 would be the same,,,just do what I told the others,,,pull off the discs and have a look. In actual fact this is a great idea because you can learn which way the adjuster goes. LSD's are a pain in the arse,,,the wheel will not spin freely.
:thumbsup::):cheers:
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-857040
:thumbsup:  :)  :cheers:
Neil.
Hey Neil, pilfering a pic from the for sale section (thanks BB GoDZilLa), is the handbrake adjust hole you are talking about the little black cap with the flat head slot set into it?
http://www.skylinesaustralia.com/forums/at...achmentid=16142
And what do you mean about the LSD? Since mine is a GTR, will I have to get the bugger up on a hoist so all wheels turn? :confused:
Thanks for the advice though! will tackle this weekend
-marcus
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-857048
Yep spot on buddy. That slotted plug is rubber and yes it's the adjuster hole,,,Great steal indeed. Now imagine a front wheel drive car,,,it's easy the spin the rear wheels because theres no resistance,,,now try it on your LSD equipped car. It's much harder to spin the rears and that makes it harder to distinguish between the spinning of the wheel and the handbrakes shoes rubbing up against the inner discs. Just be a little conservative.
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-857147
  • 1 year later...
Diggin up an old thread, but I did this today, thought I'd take some pics to save confusion for people that don't understand written tut's as well as pics...
This is on a R32 GTST, but I can't see it being too different on other Skylines.
Directions
NOTE: If you want, loosen the handbrake off in the car first, this will give you more adjustment up there to make it easier later on.
1) Chock front wheels so car dont roll
2) take handbrake off (ie. as if you are going to go for a drive)
3) Jack rear of car
4) remove wheels
5) remove rubber plug (it's not in the photos..I already had it removed)
6) spin hub until you can see the gear to adjust (use a torch) but I am guessing all skylines would be in similar position to mine, so it's at about 5-6 o'clock
7) Stick a flat head screwdriver in the hole, use the hub as leverage to push the gear up or down to adjust. You will probably only need spin it a few times unless your handbrake is pretty much not working.
8) Use common sense, it's hard with the LSD, but you want the brakes just touching, then maybe back it off one click.
9) You did both wheels, didn't you?
10) put plug back in put wheel back on....
NOTE: If you decided to loosen the handbrake in the car, make sure you tighten it back up!!
Happy days.
Cheers
Chris
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-1492517
wow, nice gold digging....
btw, if the balance between left and right braking is ok,   if you just want to tighten the lever, see the second post in this thread,  that's all you need to adjust.
Sorry but I have to dis-agree. The Lever adjuster is hidden under the console for a reason. If you do the adjustment at the rears properly you should almost never have to touch the lever one.
Neil.
https://www.sau.com.au/forums/topic/8199-handbrake-adjust/#findComment-1492993
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
