Hi Troops,
Im finally going to complete my brake upgrade and plan on doing the rear brakes.
Just need to Confirm;
- That all R32 GTS-T,R33 GTS-T,R34 GTT Rear Calipers + Rotors are 100% the same? As I tracked some cheap R32 rears down.
- Will I need to change the Master Cylinder, to accommodate the extra capacity of more pistons? Ive read a few people have, a few people havn't. Im considering not changing it if theres no real need to.
Thanks, Aerron
I looked into this. On my S2 I have a BM50 master cylinder, so will you probably. That's the same as R32 GTR non Brembo cars and is actually a bigger bore than R33GTST, so should be ok to stay with it
Hi Troops,
Thanks, Aerron
Thanks for that man. I also have a S2, so fingured crossed I have the same.
Now to get my hands on some brakes :D.
I can't remember where I got this info and it may have been posted on here, but might be useful to people.
Front discs
Model Diameter Thickness Center hole height
S15 SR20DET 280mm 30mm 68mm 54mm
R32 M-Spec 280mm 30mm 68mm 54mm
300zx Turbo 280mm 30mm 68mm 54mm
R33 GTST 296mm 30mm 68mm 53.75mm
R34 GTT 310mm 30mm 68mm 53.75
R32 GTR - non V-Spec 296mm 32mm 68mm 54mm
R33-R34 GTR - Brembo 324mm 30mm 68mm 53.75mm
Rear discs
S15 SR20DE/DET 258mm 9mm 68mm 47mm
Skyline R32-R34 297mm 18mm 68mm 63mm
Front calipers
Model Weight Material Thread Pad Piston area
S15 SR20DET 4.8kg Cast Iron 12mm DB1170 40.4mm x 4
R32 M-Spec 3.3kg Alloy 12mm DB1170 40.4mm x 4
300zx Turbo* 3.3kg Alloy 12mm DB1170 40.4mm x 4
R33 GTST 3.3kg Alloy 12mm DB1170 40.4mm x 4
R34 GTT 3.3kg Alloy 14mm DB1170 40.4mm x 4
R32 GTR ? Cast Iron 12mm DB1170 40.4mm x 4
R32/33 Brembo ? Alloy 12mm DB1520 44+38mm x 2
R34 Brembo ? Alloy 14mm DB1520 44+38mm x 2
Master cylinder
Model Type Master Cylibnder Diameter
S15 Spec R BM50 25.4mm
300zx turbo BM50/57 25.4 and 26.9mm used
R32 GT-T M-spec BM50 25.4mm
R33 GTST BM44 23.8mm
R32 GTR non Brembo BM50 25.4mm
R34 GTT ? ?
R32/33/34 Brembo* BM57 26.9mm
S2 Stag BM50 master cyl
R32 GTST
Master Cylinder diam (mm) - 25.4 area 506.71mm^2Front Caliper Piston(diam x qty) - 40.4 ×4 = 5127.58mm^2
Front rotors (diam x thk) - 280×30
Rear Caliper Piston(diam x qty) - 38.18×2 = 2289.78mm^2 ratio FR = 2.239
Rear Rotors (diam x thk) - 297×18
total 7417.36 brake to master ratio 14.63
R33 GTST
Master Cylinder diam (mm) - 23.8 444.88mm^2Front Caliper Piston(diam x qty) - 40.4 ×4 = 5127.58mm^2
Front rotors (diam x thk) - 296×30
Total area 7417.36mm^2 brake to master ratio 16.67
R32 GTR (Non V-Spec,)
Front rotors (diam x thk) - 296×32
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Master Cylinder diam (mm) - 26.9 568.32mm^2Front Caliper Piston(diam x qty) - (44+3Cool×2 ... leading pistons smaller then trailing 5309.29mm^2
Front rotors (diam x thk) - 324×30
Rear Caliper Piston(diam x qty) - 40×2 2513.27mm^2 ratio FR = 2.1125
Rear Rotors (diam x thk) - 300×22
total 7822.56 brake to master ratio 13.76
This is the ratio of master piston movement to overall brake pad movement
R32/GTR calliper ratio 15.43
R33/GTR calliper ratio 17.58
So there isn’t much difference between the Brembos and the std Nissan R32/33 GTST calipers and R32 GTR callipers
for series-1 stagea, leave the rear brake calipers alone
just add metal brake lines, Im using bendix 1144 pads, cheap at $50 axle delivered
for the front, Ive got metal brake lines, slotted rotors, new QFM A1RM 780degree track brake pads, $119 axle delivered
and installed yesterday 4-pot R32 GTR sutimoto front brake calipers
brakes are simply amazing now, stops on a dime
well i've decided that stock s2 brakes are no match for the tassie roads
had a good blast on scottsdale road and as i was coming down the other side i was loosing a lot of feel, heaps of fade and a real soft pedal (think i boiled the fluid too)
will either have to source some 33 rotors or a set of 34 calipers (which are really hard to find in tas :action-smiley-069:)
That definitely sounds like a fluid inadequacy though. Doesn't mean the pads/rotors/calipers aren't up to the task, because at the moment the weak link is definitely the fluid...
Quite possible the fluid has never ben changed. Get some Motul RBF600.
i've bled the fluid on one wide when i tried to put on what i thought were r34 callipers and it was clean coming out, may not be top stuff but its clean and pretty new
road in question is this one: The Sideling
a guy from the thermofluids lab at uni said that he would skim my pads for me if i take them off :D
looks like a good option for now, until i can source some 34 callipers
i think i may make up a bracket as i may be able to get one fabbed up pretty cheap
does anyone have a cad file for r33 callipers to gtr 324mm rotors?
think someone around here mentioned that they had one
cheers if you do, may be able to work out a cheap alternative to brembos :yes:
It might just be standard fluid in that case, which is pretty ordinary performance wise, but it's definitely a fluid inadequacy on some level. Even 'Super Dot 4' (or 5.1 as it's better known) is pretty ordinary and is really only designed for heavy duty application like towing, it's not really performance orientated...
The stuff that we use and recommend is the TRW GP600 Dot 4 Racing Brake Fluid, and is $65 for a 1L bottle. Good for 312 degrees dry, or exactly the same as Motul RBF600.
i'll give them a few bleed, a guy in the workshops at uni said he would machine my stock rotors for me for free :D
so that should hold the fort for now, looks like i'm gonna get some brackets made and run gtr 324mm rotors with the r33 callipers i have
Hi guys,
Not sure if this will help anyone but I got my front brakes on my NM35 changed today as the rotor had warped and was making the most irratating clicking and groaning sound with light brake pressure.
Got RDA954S slotted rotors and Bendix GCT Stealth pads and I have to say they feel so much better. Really firm bite and reassuring pedal feel. No shaking or wobble under firm braking at all.
If any one wants more info let me know.
aren't the RDA954S (machined down a little) the direct replacement for the C34 S2 front rotors???
I didn`t have to do mine,
& just on another note ,i have PM`D the GROUP BUY on brke line`s about sorting out replacement line`s for Stagea,
& as there a long setup he will get back & tell me what he has found,front line`s are 830mm long with block contector`s.
so hope to here from him soon,
cheer`s Chuckie.
PS i have set of 32 caliper`s retapped to 14 mm for sale if any one is looking ,as iam happy with stock pad size against clamping pressure,
not sure what to do guys
i've got r33 callipers, and r34 rotors :( (due to mistake by seller)
now i can either keep the rotors and sell the 33 callipers then buy 34 callipers (but 34 4 pots are really hard to find, $400+ from importmonster + $200+ of shipping)
or someone near me will sell me some gtr brembo rotors (324mm) for $250 and i could then make up a bracket to suit (have access to cad software and maybe to a computerised laser cutter :)) then sell the 34 rotors
or sell the 34 rotors and get some 33 rotors and some 12mm id pipe with a 1mm wall thickness
its for a series 2 rs4s - any help appreciated
thanks, Tom
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
