Good day all, i really need a good wheel aligment place who understand the nature of skylines Hicas, the nature the GTR 4WD so they can set the correct toe in/out. I'm sick of all these tyres places who thinks they know everything until you ask them if they know how Attessa work and they're like......mmm........!!!!
Please if you know a good place let me know before i go a step further to adjustable camber.
Thanks
First question to ask them is can they do all four wheels. This weeds out ninety something percent of the shops. I usually hang around and annoy the blokes whilst they are doing it.
Personally I found Bob Janes to be ok. But that is here, who knows what your local franchise is like.
i go no where else but traction tyres down my way cause its the closest of the two and when you go there you know why i go.
Yeah... Go to Traction, ask for Tony. Once you've been there, you won't want to go anywhere else.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
