I too would like to help with getting some more regular organised drifting going on.
Is Collie ready yet after being re-surfaced? Why have they not been having more events like last year (never got the chance to go to any of them :))
I'll be at Wanneroo when the comp there is on :)
Hello guys!
I hardly ever pop my head in here nowadays... I'm still in Japan but I will be coming back to AU next month sometime (for good).
I'm really suprised Drift hasn't gottten off the ground like it has in the Eastern States too. In fact (no offence to our Eastern brothers :unsure: ) I thought the guys in WA were alot more level headed and able to 'pioneer' things a bit more themselves...
Is there anything I can do? No really, I have my contacts here in Japan and Australia, so is there anything that I can help with?
I think the big thing that would help is some sponsorship and media exposure for the big day end of September that C-Red are organising.
The success or failure of the even will have a huge impact on whether or not the like so Barbegallo raceway will embrace the sport and get behind it.
When I was in SA, James Vahoumis had connections through Signal that brought TOYO onto the scene - this was a turning point, they now sponsor comps in the west, as well as drivers. Most of the major tyre companies are following suit now.
Is there anything that you think might be able to help along those lines?
exposure and sponsorship is the key IMHO.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
