  • Replies 62
Decided im leaving this place cos the new forums truly do suck, they're slow, look like shit, very hard to read, lack the features of vBulletin, and overall why would a site move to a lower-grade product?
Serious thoughts, opinions?
I must admit there a bit too dark for my liking, makes it harder to read. But give the admins a bit of time, they tend to make changes to improve the forums once they've just upgraded.
So what are you waiting for. :O
you guys need glasses or something, seriously. I run 1400x1050 res and i can read everything just fine. I dont mind it at all, looks more professional imo. what colours does everyone else have? mine is blue with white writing, again, no prob with reading or anything?
I'm sure more features, but etc will be rectified once the mods get a handle on it :O
im with u 100% on the forum looking like crap, i hate the colour scheme, and ye its failry slow even with a fast connection, i cant even view my previous posts and i cant find shit, previous forum board style was sweet, there was no need to change it completely, a big thnx 2 the designer 4 a crappy forum.
Get glasses I say. Im sure once you get use to it, it will be easier to use. Some ppl just cant handle change, maby you should see some one about that... or is it just men??
The people that made this website dont get paied to do it, its their own spare time... and run off donations... so just be happy that this site is here for ur use and that some one has alot of spare time on their hands!
/sarcasim on
oh nooooessss
a change
how dare they, my little utopia is ruined
/sarcasim off
gee they haven't added extra skins yet. white and blue is very easy to read. change the font size if your blind.
so far for me works just fine no lag, got to check out the rest of it yet but no complaints from me so far.
evolution and change are all part of moving forward, previous changes ahve turned out fine so can't see any difference now.
but come on its just a message forum, you come you read, you post, you leave you check every now and then.
My god...
Its gay. :O
Give it time fellaz.. Most gay things end up seeing the light. "No offence intended if you do swing that way"
Personaly: I run an IT forum and it just takes time.
1. They must have a reason for screwing it up like this "they upgrade to a new form of PHPBB etc.."
2. All forums like this one have different selectable skins and given time Im sure they will be up and running on this forum. After they do this you can change it to what eva look you like/they offer.
3. It needs some work me thinks..
4. This is point number 4.
5. My 2c worth.
Gee stritch you need to chill dude.
Its a day old, and migrating a forum of this size wouldnt be an easy task.
Give them some time, im sure they are quite aware of the things that need fixing but I know I would rather have a forum with small text rather than no forum at all.
yes, these forums are now very slow and the colours are too alike
same layout as the TPC forums and I don't care much for the syling ;)
Might be a newer version, but definately a downgrade I think :rolleyes:
EDIT: the time is funked too, I just posted at 2:50pm and its telling me its 6:50am <_<
Yep, no one is forcing them to do it, they do it because they love skylines and meet others who felt the same. Saying this, isnt this why we are all on this forum? So who gives a toss if the forum changes slighty or it runs a bit slower...
I sure dont, there are other much more important things in the world to get all stressed about than the skyline forming having a little change.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
