Pva_Glue Posted January 6, 2003 Share Posted January 6, 2003 anyone gets occational drops oils left over night on the floor? well I never seen anydrop comming off from my car, NONE what so ever! not even a bit! Is that good or bad? cheers Joe Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/ Share on other sites More sharing options...
predator Posted January 6, 2003 Share Posted January 6, 2003 um...thats a good thing! Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-119535 Share on other sites More sharing options...
MrMayhem Posted January 6, 2003 Share Posted January 6, 2003 is there a contest on at the momment to see whos got the biggest number of posts or something? Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-119686 Share on other sites More sharing options...
Pva_Glue Posted January 7, 2003 Author Share Posted January 7, 2003 Originally posted by MrMayhem is there a contest on at the momment to see whos got the biggest number of posts or something? hahah if you thinking I am wasting forum space... fair enough, but it's not my intension. I was simply asking is it good thing if you dont see the oil drops under the drive way... only asking because all the cars I've seen had oil marks time to time... but I never seen on my car... it's clean as... I would thought it' bad thing... cheers Joe Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-119794 Share on other sites More sharing options...
GTS-t VSPEC Posted January 7, 2003 Share Posted January 7, 2003 I can't imagine that this could be bad, I'm pretty sure most cars aren't meant to leak oil under any circumstances. If you do see oil drops then you should worry. See'ya:burnout: Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-119830 Share on other sites More sharing options...
BATMBL Posted January 8, 2003 Share Posted January 8, 2003 lol, definately a good thing, the engine oil belongs in the engine Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-120999 Share on other sites More sharing options...
Cubes Posted January 8, 2003 Share Posted January 8, 2003 My Gearbox has a slight seep from the front oil seal. The front seal from nissan is $5 so i have to get around to replacing it. BUT with my Input shaft bearing noise I am trying to hang off as long as possible hoping that it will go before the seal does. Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-121008 Share on other sites More sharing options...
akeenan Posted January 8, 2003 Share Posted January 8, 2003 Is that good or bad? :lol: this is not worth answering Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-121154 Share on other sites More sharing options...
2fardown Posted January 8, 2003 Share Posted January 8, 2003 No this is bad....your engine should leak at least 2 litres of oil a week. You might want to get it checked out. Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-121257 Share on other sites More sharing options...
Pva_Glue Posted January 8, 2003 Author Share Posted January 8, 2003 shut up you two... I got the point! :lol: cheers Joe Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-121266 Share on other sites More sharing options...
macka Posted January 9, 2003 Share Posted January 9, 2003 Originally posted by 2fardown No this is bad....your engine should leak at least 2 litres of oil a week. You might want to get it checked out. No hes serious Joe! I lose about a litre a week.. Apparently a screwdriver and a hammer will get it back to 2 litres. You the sphincter of the universe! Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-121303 Share on other sites More sharing options...
Pva_Glue Posted January 9, 2003 Author Share Posted January 9, 2003 seriously I never had problem with my engine... I think RB25DE is the best! the best! cheers Joe Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-121334 Share on other sites More sharing options...
akeenan Posted January 9, 2003 Share Posted January 9, 2003 the more oil you leak the cleaner your engine will be. Just keep toping it up to the correct level. Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-121352 Share on other sites More sharing options...
Cubes Posted January 9, 2003 Share Posted January 9, 2003 The Nissan RB is the best Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-121759 Share on other sites More sharing options...
(B1) MR_fanny Posted February 27, 2003 Share Posted February 27, 2003 hey guys ive come to the realisation that the reason u dont see minor oil drips is because the plastic underlay under the engine actually catchs the drippin oil......thats why u dont see any on the ground hehe:D im abit worried cause i had a look at that underlay the other day and saw some spots where oil has been drippin on it. so the question here is whats the possible cause of the oil leak?? thanks Link to comment https://www.sau.com.au/forums/topic/8272-oil-drops-from-the-engine/#findComment-186381 Share on other sites More sharing options...
