Hey Christian,
An item from my wishlist.....I normally browse the forums for new topics then subscribe to them for updates.
With the new forums there are 2 cosmetic problems with the subscription emails:
They all have the same email topic "Topic Subscription Reply Notification ( From Skylines Australia )" - I much prefered the vb function where the topic of the email is the thread title
When you open the email the link to the thread is the last thing in thew email so you have to scroll down a page or two within the window. It would be much more convenient to have it near the start of the email so we don't have to scroll.
Keep up the good work :)
https://www.sau.com.au/forums/topic/82777-email-topic-subscriptions/
Actually one other thing to add here, for some reason even though I choose the "Delayed Notification" option I still get multiple emails for each post when I am not on the board....I am looking for an option that sends 1 email on the first post after I leave the board if that makes sense
yeah it does look better thanks mate.
is it possible to make the topic of the thread the topic of the email? vbull used to say something like
Reply to post "What is so appealing about post-whoring"
