jay wrote this in events thread:
Scrutineering is on the Fri 1pm to 10pm. If reqired can be done on Sat by appointment only.
You will need
Cams licence minimum level 2S,and current drivers licence
Cams -affiliated car club membership card
Registered vehicles need CTPI insurance extension valid for
this event
All apparel including helmet and approved shoes, non flamable
neck to ankle/wrist....total ban on nylon or similar material
All pit crew must attend scrutineering
registered cars need minimum lap sash seat belts
fire extinguisher securly fitted
Double throttle springs
Road legal tyres ( tubeless tyres must be fitted to optimum
size rims eg Stock 6.5ins mags must have 205 tyres)
blue triangle for battery location, white comp no, 100mm high
top left of windscreen (supplied by you)
Noise level 95dBA measured at 30m from track edge at any
time
so whats the go there???
https://www.sau.com.au/forums/topic/8287-street-sprints/#findComment-124300
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
