I think were going to have to put a copyright on the team wang name snowie.
It all started in a galaxy, I mean vic coutry town far far away.... (Wang eratta)
Where young males come together with a common interest of racing their wangs.
got it :lol:
  • Replies 227
Posted Images
Ferni...and everyone else..are you driving up on the sat?  If so do we want to organize a convoy?
Sounds good, so far Ferni and I are going up together with about 4 other cars (spectators). We should organize a place and time to meet…
Edited by MSPEC
Ant (and anyone else)
A few of us plan on doing a special run up to Benalia the back ways on Saturday with a stop off at Buxton to try out Victoria's best burgers!
:D
Check it out.
http://www.theage.com.au/news/Epicure/Burg...8514953113.html
Anyways - it means a run through the twisties - hell we may even go the super long way through Reefton yet - but we haven't decided.
Will be leaving the SouthEast / Ferntree Gully area around midday.
Sounds good snowie...although don't forget my little gtst trying to keep up 'round the twisties :D
Anyway it is a huge weekend for me with this track day and moving house on the monday so I'll have to confirm if I can make the midday convoy next week.....
Yeah i'm happy to do a cruise up on sun morning, will have to be early tho. 8am scruit. What time will we have to leave and wheres a good place to meet? Last time we met at ferntree gully maccas....
I'll be there.
Sunday morning, whereever it needs to be.
Let's say 5:30am LEAVE THE MEET
250 kilometers, is 2.5 hours.  5:30 + 2.5 hours is 8am
just in time for scruit
I will so be asleep at that time. LOL
Well there is no way I'm getting up THAT early on any Sun :D
Bec...don't worry if I do miss the midday cruise, I'll just have to play catch up :O
Where were you thinking for a meet place Snowie?
Blaise and I were cruising to Scotsmans house (F/G) and going from there.
There is a maccas on left hand side of dorset road in bayswater (you drive past it when going to racepace) as you drive north. I say thats a good meet point then we take the route pointed out by the yellow line on the map attached. I'm open to adjustments however.
Thats the macca's out front their little shopping complex there?
Ferni - not only did you pick the quickest route - its also the funnest!!!
Geeee what a coincidence :O
If i had cruise control the hume may be the go, but luckly my car can turn corners without coming to a stop.
MSPEC: Yep, thats the one :D
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
