Mkay,
Still doing my homework.hunting around... what would you guys pay for a:
1996 Series II, R33 Skyline
40, 957kms, immaculate interior.
Aftermarket Shift Knob
Turbo Timer
Possble TV System
GTR Rear wing
Nismo Clear side repeaters
Front Lip
Air-filter (K&N ?)
Aftermarket larger radiator
Turbosmart Single Stage Boost Controller
Large Front-mount Intercooler, possible HKS (blue piping, Heat-coated)
Nismo front strut brace
Possible after-market turbo
Gold 17's with bridgestone rubber
VERY TIGHT Nismo rear LSD
MD AND CD Changer
Rear strut brace
3" Mandrel Exhaust
TEIN HA Suspension (rock hard)
Apparently this car has 200rwkw... but yet remains to be proven.
Any bids ? what would this be worth ?
https://www.sau.com.au/forums/topic/831-what-would-you-pay-for-this-96-spec2/
How did i know URMINE would have a crack on this thread.
Private import more like $24-25 due to VERY low kms.
Several import yards are selling top quality series 2 models with low km's for up to $32K!!! the funny thing is people pay it to!
Several 96 models come through ex japan for the 20-22K mark however they ALL have around 90,000kms and/or accident history or condition issues
pay for what you get especially if you are consious of km's which many people are.
If you dont care about km's you can find a dirt cheap series 2 for around $21K and up.... bargain.
I would have said $29K here in Aussie
Private import is another situation totally and yeah, $24K possibly because of the extras, the kms and condition.
$22K is fo rthose accident damaged high kms cars as BY BY said.
Here's an update:
I DROVE the car...... OMG! this thing is the BOMB!
204rwkw apparently. aftermarket turbo confirmed.
This diff is awesome.. click click click... very nice. grips like shit to a blanket.
The clutch had been replaced with a new ceramic one.. very ON/OFF'y.. nothing in between. had to let it out ever-so slowly.
Well, this skyline has opened my eyes!
FYI: It's on the yard for $32,000 which I think is WAY too much still...... $25k YES.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
