Just picked up my car from Racepace on Staurday with the addition on a HKS 2535... Its an R33 GTST S1.5.
I have to say i am wrapped with how the car has turned out it goes so much harder than it used to and the power delivery is smoother than ever!
Big thanks to Ben and i recommend anyone else to send their car to him!
If anyone is looking for a turbo upgrade, the 2535 is amazing! Not much more lag but it just pulls and pulls the harder you push it the harder it goes! The power is so smooth that traction is not a problem at all....... first gear is a little useless above 4500rpm but second gear is great and that is with the crap Falken 326 265/35/18...
The best thing about the car is that it looks stock standard! You cant even see the turbo under the heat shield...
Big thanks to Ben and ill be back very soon for more work!
https://www.sau.com.au/forums/topic/83237-hks-2535-installed/
PFC
Trust FMIC
Turbo Back Exhaust
12psi
Nismo Fuel Pump
211rwkw....
I am getting an new catback exhaust so i can run more boost and was told to expect in the range of 240 - 250 rwkw...
I am more than happy as it is now but the extra 30 odd kw will be great!
Ben said it drives a lot better than the dyno shows... for now i am very happy with it!
I guess that would have been mine!
I forgot to mention, Nismo Fuel Pump as well but still running the stock injectors and AFM...
I was more than happy to upgrade the Injectors but Ben told me not to bother... They only start maxing out at redline, which my car never really sees...
I have been getting used to the way the car drives so to be honest I havent noticed when it hits 12psi and it wasnt on the dyno readout so ill have to take her for another spin an let you know..
Standard manifold, just looks like a 100% factory engine bay...
After a goo thrashing over the weekend, i can tell you it loves to drink if you push it and the power delivery is so smooth that sometimes it really doesnt feel like it is going hard till you realise who fast you are going...
I have been searching high and low for a good cat back system but have found it is very limited... anyone got any suggestions? I have tried hypertech but thats it so far... and i wasnt that keen on spending another $1200 on a catback..
I have a Blitz Spec R at the moment whcih will be for sale if anyone is interested....
Let me also say that unless your car is standard, the Falken 326's are useless!!
211 kw is not so bad but why not more?
I got 208 on Rajabs low reading dyno at 12 psi thats with a stock CAT and a stock dump pipe and a Unknown remapped ecu.
I know a guy that has a SII R33 GT2535 with 236 rwkw and a tuned PFC. He ran it at the drags with mickey thompson slicks and got 12.7 but was getting 109-110 mph. Mine was getting 111 mph at lower boost, minus computer and exhaust sections.
Is it worth paying all the $$$ for the HKS turbo? I certainly USED To think so, ive had a GT2530 on a SR20DET before, but now Im beginning to question if the outlay of money for these ballbearing turbos is worth it.
Not picking at anything, but its something to think about.
Ben Dyno is LOW reading too. Is it worth getting HKS turbo or local ones? Look at the smile on Silva33 face :).
Don't try to squeeze too much boost because it'll be either your turbo and engine wil go Bang.
I used to have a 33 series 1.5 too, stock turbo, always run 14psi for Three years and nothing ever happened.
hmmmm interesting... im going to be building up something with a 2540, fmic, afm, pfc, bigger injectors, fuel pump and cams so it will be interesting to see how much power i get... as i want it reliable i will only be running lowish boost (12psi - 1bar max) and the power ur getting is about all i want.
It didnt make anymore power with the silencer in the exhaust and without the silencer you can hear me comming from a block away, thats why im looking for a new quiet catback exhaust...
I think the turbo is worth it, when you consider how responsive they are and how smooth the power delivery is i dont think you can go wrong... and the fact that the car still looks standard is a huge bonus...
As far as the motor going 'bang' ill leave that up to ben.. I dont expect anything more than the turbo and motor will safely handle... I am more than happy with the performance at 211rwkw, so anything above that will be a bonus!!!
For normal day to day driving the only other turbo i considered was a VG30 hybrid... I ended up going for the HKS because of the reliability of the results....
so the 2535 is low mount obviously...
does anyone know if the 2540 is a low mount turbo?
lol... narkehh! it can be a 'low mount turbo' if it's mounted on a low-mount manifold you goose. Same goes for a high mount manifold. The manifold determines your turbo mounting position, not the turbo itself! provided you have the space required of course..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
