Sometimes if they are going fast enough there is no way they can stop in time due to they weight and speed thing so they only thing they can do is go faster and hope they make it instead of trying to stop and ending up in the middle of the lights. But i agree sometimes truck drivers suck i have usually get problems with them changing into my lane when im right next to them and ive been run off the road a few times and ended up driving in the emergency lane!
Guest GR33DyMANGO
yer ive had a few close calls with trucks and buses. i always try at anticipate the stupiest thing every other road user could ever make.
thus, i always try to keep a large distance between other vehicles. when it comes to trucks and buses i never sit besides one.
talking of truck stories my gf was going around a round about and one nearly swipped her off the road. it went right into her lane so she pulled the finger or something(cant remember exactly what happened). then the truck driver stopped his truck in the middle of the round about so she couldnt move, got out of the truck and came up to the window shouting "wind down your window," while waving his finger at her. she reversed as fast as she could and got outta there.
oh yer... and i remember a few years ago there were heaps of accidents caused by massive trucks smashing into cars on leach hwy or something killing a few and putting many others in wheelchairs for the remainder of their life... or causing some to suffer from permanent brain damage. i think i might recall the cause of the accident was that the truck driver (as im sure is common among many) hadn;t slept for days and was full of drugs.
hmm havent heard of that one.. but there was the one down greenmount when the truck lost its brakes and mashed into the cars at the midland/roe interchange.. BAAAAAAAM. now they have the truck arrester beds down the hill.. would love to take the bunky into that. hehe
Shaun
I've been in a truck before (passenger) in Sydney and you should see some of the dumb arrogant pricks in cars, In most two laned roundabouts you cant go wide enough out and the trailer will pull in (speed is not a factor). Just because when your pulling a trailer in your car and you can go round a roundabout with no hassels doesn't mean a truck can.
Sumo
I don't have a problem with trucks, but I think that when approaching lights they should go a speed in which they can stop. If that means slowing down as they approach green lights then so be it, they should be in the left lane anyway.
See'ya:burnout:
Guest GR33DyMANGO
speaking of craziness... i was going along the causeway bridge at about 9.30 last night (it was pretty busy, lots of cars everywhere) and this major retard with the one of those crappy old boxy fords and the 5HITEST caravan ive ever seen decided to stop in the middle of two lanes suddenly (nearly causing a pileup) then just did a U-turn onto the other side of the road nearly hitting more cars????
some people are seriously retarded.
Originally posted by azazel
Sumo,
They shouldn't be on the road if they physically can't obey the road rules (can't stay in their lane on roundabouts). Just like the big load trucks that couldn't stop for the red lights, get em off the road before more people get killed.
yep thats the way lots off smaller vehicles will push the prices of everything higher and we will all be better off. Especailly all those extra drivers needing to be employed. Pity even with a job the costs will be too musch for anyone to buy food etc Maybe its the road designers that are of more concern
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
