Fs: My R32 Skyline With R34 Neo Engine
  • Replies 62
Posted Images
was looking arround import sites and came accross ur 2nd baby
http://www.fourbrotherimports.com/cart.php...ddcountview=Yes
sum1 must be getting interested by now
Guest Miss_Nismo
there has been interest, but everyone wants a bargain - offers of 13k etc, there really isn't any point selling the car for that price, i could take the engine out and sell that for 5k, and then sell the car standard engine for 13k.
true that just the work involved :P
gl selling it ... since uve still got it u should come for the cruise to victor on sunday 19th feb (this sun)
Guest Miss_Nismo
don't think it's a good idea to be taking my newborn son on a car cruise, but pawley and I might come to the meeting point just to say hi.
ill be taking my daughter she is little older than new born but i would take her is she was new too
do u live up near clovercrest shop within 5-10 mins walk of it :) depending on whos walking
Guest Miss_Nismo
Serisou couple of questions. What ECU / loom is it running and what gearbox?
Replaced VL turbo gearbox roughly 12 months ago with R32 GTST gearbox which should handle up to about 220kw no problems, this car is currently running 178kw and the gearbox is sweet.
Car has R34 ECU.
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
