  • Replies 63
Pred, without being an expert on the subject, it appears to me the most economical means of producing higher flowing injectors is low impedance, while Nissan use an ECU that favours high impedence or lower current handling transistors.
Waldo, just use a multimeter to measure impedance (ohm symbol or the horse shoe shape) then calculate the correct resistor to bring to the correct value of between 12-14ohms.
Given the cost of the resistors is about $6 I'd say even $130 is a scam.
ok just went and measured the resistance using a top of the line mega, the GTR injectors measured out to be 1.88ohms and the standard RB20det injectors measured to be 14ohms exactly, so i will use 12 ohm resistors to correct the resistance. Hope this helps anyone
I've just measured the resistors in the resistor pack in my R32 GTR....each has a resistance of 5.5 ohms. I also measured the L-jet resistor pack that I have, which is either from an r30 or a 280ZX (I can't remember, but it doesn't matter as they use the sam injector system, more or less)...each resistor also has a resistance of 5.5 ohms. So using an R30/280ZX resistor pack is an option, although as I said the connector is different.
i dont understand how this works, if each resistor is reading 5.5ohms in your resistor pack then the total resistance of the gtr circuit would be 7.5 ohms....does the rb20 have a resistor pack at all for the injectors? so its means if u stick gtr injectors with the injector pack you will still only get a reading of 7.5ohms whereas the rb20 injector resistance is 14ohms...i must be missing sumthing
i think i understand it now....with injectors the computer sends a signal to them for example at 2000rpm it will send 3 volts, and at 7000rpm (full throttle) it sends 12v. by having more resistance (14ohms) the volts that are going to the injector will be significantly less, say 5 volts at full throttle instead of the required 12v, this is because more resistance you have it will lower the volts, but not having enough resistance it will fry the ecu. So therefor you would have to find a medium, say instead of making the total resistance 7.5ohms make it 10ohms, so that the injectors can still receive an adequate amount of volts and then its just a matter of the tuner to change the volt range at differant throttle points...
SteveL do you have any rb20det injectors if so what resistance do you get with those
Umm, this is a bit confusing from those figures for the impedences. Time for some research.
Sorry Waldo, the voltage will always be the same, just the switching frequency and timing for open/closed will differ with rpm.
Just having a think about this. With the GTSt's I'd suggest keeping the same impedences to suit those computers if making a pack, but enough success is had using the GTR resistor pack to warrant anywhere from 8-14ohms impedence.
Anyway, it could be an expensive error. Worth further investigation.
I don't have any RB20DET injectors...sorry. The injectors always see the same voltage...it is the current drawn by the injectors that will be different - but I'm no electronics tech. The way I understand it is this....injectors with low resistance (2-3 ohms) are used where fine control is required because they have opening/closing times which can be tightly controlled. OTOH high resistance injectors do not have the fine control capability, but are by far the most commonly used (so might be cost issues, etc).
The crucial thing is that the injector drivers in the ECU will be 'matched' to the injectors, so if you are going to use GTR injectors (low resistance) with an RB20DET ECU designed to be used with high-resistance injectors I would have a tendency to add a sufficient resistor value in parrallel with each injector to more-or-less match what the ECU would normally expect to 'see'. I doubt that you need to get things 'exact', butmy understanding is injector current has a crucial effect on injector life as it effects injector heating.
Aftermarket ECU's (eg Motec) have more complex injector drivers which can vary injector current via software settings, so they can cope with a range of injector resistances.
With regards to splicing it in to the loom.
Do the GTS-T owners simply cut the plug off and begin soldering directly to the loom or??? :P
Nah, i kept the plug and spliced the wires into the loom.
One day when that girl next door finally confesses her deep seeded love for me, my lotto numbers get up and my RB20 makes enough power to strain GTR injectors, well with the plug then all i need do is unplug the resistor and plug in a leed that simply loops the wires back together so that the ECU will once again see low impedence...allowing me to run RB20 550cc injectrs etc etc
As Roy says there are 7 wires in the resistior pack plug. In the case of the R32 GTR resistor pack, one wire is white, the other 6 are black. The white wire is connected to the battery +ve terminal, so carries +12V. Inside the resistor pack the white is connected to one end of each of the 6 resistors, the opposite end of the resistors is connected to one each of the black wires. Each of the black wires connects to one terminal of each of the injectors. The other injector terminals are connected to the ECU. The ECU fires the injectors by intermittently earthing the injector terminal connected to it.....current flows, etc, etc.
In the case of engine control systems that don't use a resistor pack (GTSt's, etc), there would still be 6 wires connected to one terminal of each injector for +12V feed, but at some stage in the loom they would all become connected in common down to a single wire to the battery. It would probably be a case of some wire tracing to track that join, although I have seen an RB20DET (red top from memory) that had a small 'sub' loom for the injectors (sort of like the sub loom for the coil packs). Don't know about RB25's.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
