bwahahaha who's this spy and what with this "I can't show you my engine bay as your a spy for Buster" hahaha has Buster opened his own workshop? mmm nope
guess I'd better get the car finished for this show down, no use in having spy's out there and not racing
  • Replies 520
Posted Images
i heard from busters spy's friend's sister that buster has the hugest turbo ever and a secret inlet manifold and naws. the size of his turbo is dwarfed only by the size of my wang... now that is a serious turbo...
this just in. After reading my post it seems someone has gone on an upgrade mission. i've been sent this pic of spys mate with the T88. seems word has gotten out about busters 'two of the big ones'...
Adam,,,I'm interested but I don't understand a few things, can I run my Sports Sedan and what sort of licence would I need?. If I need to purchase a licence and/or alter the car,,, what sort of money are we talking. I have a budget to run my car and don't want to blow it just to see what it will do in a straight line.
Neil.
They were happy to let UAS John run unregistered last time. Just need an ordinary drivers licence and some ownership documents. Have you got a rough guess of the time it might run?
Adam, as usual count us in mate :D:D:D Will send you a PM about it
I could also have a possible 10 other entries unless they join this forum as well and express their own interest....
Adam, clean out yoru PM's as well mate :):D
My pm space shrank overnight. I'm innocent!!!!
Bring em on. You can deposit the money for them if you want or they can email me at sarpi at punkass dot com. If they are completely removed from us then I would like it if you organised them a bit. Send me an email or pm if you have any more questions about it.
I think this one might be even better than the last one.
John had to get tech inspected first!!!
Call Geoff Crisp @ ANDRA on 0414254135 and organise to have it checked over before the meeting.
Adrian
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
