17x10 +18 would be my pick for a R33 GTR. 9" +35 is too thin and offset is too high, +18 is a bit better than standard, but if u were going to have a 17x9 id stick with stock R33 GTR rims as they are better quality than the enkeis. 17x9.5 +38 is too high offset, +18 would work, but honestly if i was going to spend the $$ id do it right first time and go 10" wide. gives u more options.
Thanks, I'm having a look around and most tyres that are 255/40/17 or 265/40/17 are a large difference in price, which would be my main reason for going for the 9.5".
However the difference between 9.5 and 10" is about 7mm more sticking out in the 10" and 1mm less clearance, so the 10" is looking more tempting, I *could* run 255/40/17 on a 10" but might be a little stretched....
But I saw this section of this thread and 255 don't look stretched on 10" rims, hmm 10" is looking good.
Skyline model = r33 gtst
Wheel diameter = 20"
Wheel width = 8.5"f 9.5"r
Wheel offset = ?
Tyre size = 225/35/20f 245/35/20r
Modifications to fit = roll guards a little.
sometimes scrubs when turning and hitting bumps together.
Skyline model = r32 gtst
Wheel diameter = 18"
Wheel width = 8.5
Wheel offset =
Tyre size = 235/40/18
Modifications = car is lower and has the big R33 front brakes
(best pic i could find to show how low it really is) (is the tires and wheels specs above)
any one had a problem with the inner side of the tire scubbing the top of third link front only?
Edited by nissans52
Skyline model = '97 R33 GTST
Wheel diameter = 17
Wheel width =8s, 9s
Wheel offset =+40 +40
Tyre size = 235/45
Modifications to fit = None
Fit good. May consider 10mm or 20mm spacers at some point after I lower it a bit. May go for a lower profile tyre also.,
Edited by Battery_backup
hey mrbenno,
can u email me at [email protected] ?
sorry im not able to send u a private message as im still new.. im interested to see how your emotions look on your gtr32, as im planning to get thjose too, same size offset and width..
thanks
Skyline model = 1989 R32 GT-R
Wheel Brand = Work Emotion XT7
Wheel width = 9.5"
Wheel offset = 20
Tyre size = 245/40/18
Modifications to fit = None.
Car is quite low, as low as a set of super low springs if you had them. ( I have Teins)
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
