17x10 +18 would be my pick for a R33 GTR. 9" +35 is too thin and offset is too high, +18 is a bit better than standard, but if u were going to have a 17x9 id stick with stock R33 GTR rims as they are better quality than the enkeis. 17x9.5 +38 is too high offset, +18 would work, but honestly if i was going to spend the $$ id do it right first time and go 10" wide. gives u more options.
Thanks, I'm having a look around and most tyres that are 255/40/17 or 265/40/17 are a large difference in price, which would be my main reason for going for the 9.5".
However the difference between 9.5 and 10" is about 7mm more sticking out in the 10" and 1mm less clearance, so the 10" is looking more tempting, I *could* run 255/40/17 on a 10" but might be a little stretched....
But I saw this section of this thread and 255 don't look stretched on 10" rims, hmm 10" is looking good.
Skyline model = r33 gtst
Wheel diameter = 20"
Wheel width = 8.5"f 9.5"r
Wheel offset = ?
Tyre size = 225/35/20f 245/35/20r
Modifications to fit = roll guards a little.
sometimes scrubs when turning and hitting bumps together.
Skyline model = r32 gtst
Wheel diameter = 18"
Wheel width = 8.5
Wheel offset =
Tyre size = 235/40/18
Modifications = car is lower and has the big R33 front brakes
(best pic i could find to show how low it really is) (is the tires and wheels specs above)
any one had a problem with the inner side of the tire scubbing the top of third link front only?
Edited by nissans52
Skyline model = '97 R33 GTST
Wheel diameter = 17
Wheel width =8s, 9s
Wheel offset =+40 +40
Tyre size = 235/45
Modifications to fit = None
Fit good. May consider 10mm or 20mm spacers at some point after I lower it a bit. May go for a lower profile tyre also.,
Edited by Battery_backup
hey mrbenno,
can u email me at [email protected] ?
sorry im not able to send u a private message as im still new.. im interested to see how your emotions look on your gtr32, as im planning to get thjose too, same size offset and width..
thanks
Skyline model = 1989 R32 GT-R
Wheel Brand = Work Emotion XT7
Wheel width = 9.5"
Wheel offset = 20
Tyre size = 245/40/18
Modifications to fit = None.
Car is quite low, as low as a set of super low springs if you had them. ( I have Teins)
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
