Nisskid, you are the man!
Rather than reading through 31 pages to get the information I require, would you kindly be able to tell me what is the widest wheel width, wheel offset and tire combination that I could run on an R32 GTS-T without lipping, rolling, pumping guards etc?
Thanks champ :)
Edit: On an 18 inch rim
Edited by Sparkys
Hi,
Would 225/45 (front), and 245/45 (rear) have any difficulty?
Thank you.
with standard camber arms the rears will probably JUST scrub on standard guards depending on ur suspension, fronts will be fine. if u have camber correction on the rear ur rears will almost certainly scrub to an extent. a guard roll will stop that tho, no need for a flare or anything.
Thanks champ :cool:
well, this ones slightly difficult, i ran a 9.5 +38 and i still consider it the widest possible setup without overlapping the rear hicas rod end, with standard camber arms, and standard guards. i ran a 255/45 on it and it just scrubbed a tiny bit.
now few issues here, the 255/45 profile is too high really, ud be better off with a 255/40, this will help with scrubbage. as mentioned i was running standard camber arms, this gave me more clearance as i ran more camber than i do now (-2 then, -1 now), if ur after maximum grip u would be best running around -0.5 camber or so, which will pull the top of the tyre out and completely throw out ur fitment. then the final issue, and probably the most important is whether the design of the wheel fits over the hicas rod end. now just about all 17's dont, but some 18's do. there's no way to find out whether they will or not without trialling it out, each wheel uses a slightly different rim design. if it does fit over it means u can go a much higher offset which will allow u to go wider.
i know it's not a comprehensive answer, but there's always a few factors that get u when ur aiming for tight wheel fitment.
Thanks mate. The wheels I'm chasing (and saving for) are Volk GT-C in Spark Silver.
So based on your information if I get a pair of 18 x 8" with a +38 offset for the front, and a pair of 18 x 9" with a +38 offset and fit them with a 235/45 on the front and a 245/45 on the back to be safe I should be ok.....
I have stock suspension. Thank you, for the info.
firstly, those profile's are too high, so im going to assume u mean 40 profiles and go on that.
on the rear, yes, as long as u have standard camber arms, it will be tight, i cant guarantee no scrapage as every car is different, and suspension plays a big role. if u want to go as wide as possible there is work to be done, 9" and 10" can be fit under unflared guards, with 235/40 and 255/40 quite easily.
front will be tight with the upper control arm, my guess is it will foul. once again every car is different, but if be going for a maximum of +30 offset.
what exactly are u after? as if ur just after looks, then u could save urself a lot of hassle by just going a smaller tyre, if ur after performance then ur going to have to look into camber arms and reduce ur camber, then we will be starting from scratch, there's no point running really wide tyres to get straight line traction if ur running a lot of camber.
Predominantly after a nice flush look with the guards, on an 18" rim. Not aiming for the absolute widest I can go coz not keen to lip roll etc. My offsets guesstimations may be wacky! If I went for an 8" rim on the front and a 9" rim on the back, what offsets and tyres would you recommend?
well 2 things, if u want a "flush" look ur going to have to roll ur guards and go a smaller tyre or wider wheel (my suggestion)
if i wanted a tough look with 18's on just rolled guards but didnt want to stretch a lot id go a 18x9 +25 with 235/40 and 18x10 +30 with 245/40, with a decent roll they wont scrub. thats also assuming ur running stock arms.
hey everyone, i want advice from you experienced guys,,, i have a r34 gtt and i want to get 18”rims,, i was thinking about getting the rear ones wider than the front ones but i dont want to do too much modification to my car to fit them,,, my question is what width rims should i get in the front and in the back and what offset??
btw right no i have on the car that fitting with no problems
front: 17x8 235/45ZR17
rear : 17x9 255/45ZR17
thanks a lot for your help and adviceS
I think with standard guards you've got decent tread as it is. If you like the fitment that you have now then just get the same in 18's.
The tyre sizes would have a lower profile. Like 235/40/18 instead of 45 profile.
Are you sure they're 255/45/17's? That seems a bit high?
thanks for the reply Russell
yeah i'm sure of the size,,,
but i went to do alignment and wheel balance today and found that my tyres so worn off they almost look like slicks,,especially the rear ones, i had them installed new a year ago so i've been on them for 20000km at most, and i didnt do the alignment since i installed them,,, i dont do burn off or drift with my car, but i drive fast,,
do u think they are worn off because i didnt align them regularly or do u think that happened because of their size
btw i did cut the black plastic where the used to rub when i turn sharply, but that was when i first fitted them on the car
They are not worn out because of the size. It won't really matter.
If you care about tyre life get an alignment every time you fit new tyres.
and if u thrash or see some track, then more often than that. i try to get an alignment at least once every few months, and rarely is it still within spec when it gets on the aligner each time.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
