What about a 265/35/18 then? i just wanted to get a wider tire so the rim doesnt stick out futher than the tyre wall and it wont look like the wheel sits in the guard as much,the 40 series is a much nicer ride on the road too coz i have all ikeya formula controll arms top and bottom around.
This is for the front will be rolling rear guards soon so i can fit my rears
Skyline model = R33 GTS-T 1997
Wheel diameter = 17"
Wheel width =9
Wheel offset =22
Tyre size =215/45
Modifications to fit = slightly lowered on coilovers still running splash guard
hey guys, Im trying to pick some new wheels n sizes. What's recommended for r33 gtst with standard suspension,
currently have 17 x 8fronts(not sure offsets), 17 x 9rears with 235.45.17 tyres and have heaps of clearance lol..
I would like to go for 19's or 18's dish type wheels but unsure of offsets, cambers and clearances. dont want to do any mods to fit and I will lower it with coilovers to suit after wheels fitted. Thanks for any help
ok lads, got new sizing in mind, and im gonna get the rears flared if need be cause this is the look i want
work emotion XD9's
rear: 18x10 + 18 225/40/18
front: 18x9 + 12 215/40/18
I will definitely be running some camber on the rear (bout 3 degs) and some on the front if need be...
how are these gonna fit mr nisskid?
work emotion XD9's
oh for a 33 gtst btw, with the rear guards rolled flat already
work emotion XD9's
very aggressive, very nice :down:
use camber adjustment to get the fitment just right.
work emotion XD9's
Hey Braddd, this is my first post and I don't want to come in too hard straight off the cuff, so forgive me if this sounds too authoritative, but you know thats not legal right?
225/40R18's shouldn't be mounted on anything bigger than a 9" wheel.
215/40R18's shouldn't be mounted on anything bigger than a 8.5" wheel.
with that in mind have you considered;
rear: 255/35R18
front: 225/40R18 or even a 235/35R18 (a bit hard to find)
its all about the stretch! haha
are you sure 225/40 is legal for 9" rim? i would have thought youd be pushing it..
bradd u wont need to flare rear just roll guards and camber should look tough as! ive got 18x10 +20 and i just rolled but havent dumped it yet may need more guard modification when i drop another inch.
also nisskid what are the chances of fitting a 255 or 265 under r33 guards lots of camber im guessing?
again, I'm not trying to be a smartarse here, just trying to provide some help... :P
According to the Tyre & Rim Association of Australia Standards Manual, which is what all state authorities reference on wheel & tyre standards, a 225/40R18 may only be mounted on a 7.5" - 9" wheel. (Nominal width is 8").
It's worth mentioning that this manual supercedes any claim made by a manufacturer regarding wheel width min-max.
This from the website:
The Standards Manual is a necessary reference for all tyre and wheel manufacturers and retailers, as well as vehicle and implement manufacturers, vehicle service organisations, transport authorities, government bodies, road and traffic authorities, fleet operators, agricultural vehicle and machinery users. Current Standards Manuals are a nominated standard for many Australian Design Rules (pertaining to the design and manufacture of automotive products) and State Transport and motor vehicle regulations.
is this manual what police will defect you via?
i got done on the weekend for a 235/40 on a 18x10 so now im thinking ill just stick the right size what is recommened for 10" in your book pls?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
