It will look retarded..... I sense some vomit coming up already..
Unless! You flare which would require a fair amount of body work, Low and camber tuck hard AND if you did id be pretty jealous because I wanna do it haha
I'd try something like a 18x10 with between a 0 to +10 offset, that would look amazing!
Oh and I got my fronts on today..... So happy!!!!
im gonna ask what is possibly a dumb question but im happy to hear all input.
got 18x9.5 +38 Work emotion CR Kais.
275/35 on teh back and fit fine.
245/40 stretched on teh front....and they dont get past the brakes >.<
car is a 33 SII GTS-T, no guard mods front or rear whatsoever atm.
is 5 or 10mm spacer and/or guard roll the correct course of action from here?
cheers
sean
spacers are your only option to clearn the brakes. as for guard roll depends if you need it once wheels are on.. i think you might get away with it if you put a smaller tyre 275 is farkn huge dude.. ive got 265 on a 10" and thats to much.. try a 245/255 u can even go 235 but that'd be fair stretch'd also spacers all round is not something i'd want to drive around on i hate them depending how much its not clearing by u might get away with a small slip on spacer of a couple mm.. just a thought
better advice sell them and get something with a better offset.. but if u dont do this give the above ago a post pics of result :(
lol blags.. saw u last night cruising through t/c wheels looked toughhhhh!
so with 275s the right rear fitted fine, and the left didnt >.> so light guard roll at the left rear and it was sorted. the front will be running an 8mm slip spacer and longer studs, with a touch of camber. will test drive after spacers and see if it needs a guard roll. rear looks great atm, cant wait to get em on all round :(
235 on 10" is fair stretch i had it..
batak - pizza hut called they want their pizza slicers back
sean put the wheels up for sale its really the best bet trust me u dont want to be running on spacers front and rear its shit, voids ur insurance (not that that's the major problem) and will drive like balls.
i dont think disk type matters much on cr kai's? just re reading above to.. u sure 8mm is enough that will only take ur offset to +30 still pretty high
im not running spacers on the rear... not sure where you got that from
and yes at the front. 8mm clears the brakes. 3mm didnt, 5mm didnt, 3mm+5mm (just to test) fitted and obv 10mm did. so a single 8mm will work and im happy to do that after fitting longer studs..
Skyline model = R32 GTR
Wheel Brand = Work XD9
Wheel diameter = 18"
Wheel width = 10"
Wheel offset = +18
Wheel weight = ??
Wheel + Tyre = ??
Tyre Brand = Falken RT615 Azenis Semi Slicks
Tyre size = 275/35/18
Brake rotors = Vspec II Brembos/Rotors
Modifications to fit = Front - None. Rear - lipped gaurds
nice offset.... will require camber OR flare, but not both
personally i'd go flare and keep the rears on the road :D
changing to +15 17x9 and +18 17x9. due to issue with brake clearance on the front (silly ap calipers)
running +23 9inch atm wonder how it go with the +18
here is what it looks with a 8mm split on so +15 front
edit: with my front bar on
Note: R33 gts-t with stock front guards no rolling
Edited by Kaido_RR
