It will look retarded..... I sense some vomit coming up already..
Unless! You flare which would require a fair amount of body work, Low and camber tuck hard AND if you did id be pretty jealous because I wanna do it haha
I'd try something like a 18x10 with between a 0 to +10 offset, that would look amazing!
Oh and I got my fronts on today..... So happy!!!!
im gonna ask what is possibly a dumb question but im happy to hear all input.
got 18x9.5 +38 Work emotion CR Kais.
275/35 on teh back and fit fine.
245/40 stretched on teh front....and they dont get past the brakes >.<
car is a 33 SII GTS-T, no guard mods front or rear whatsoever atm.
is 5 or 10mm spacer and/or guard roll the correct course of action from here?
cheers
sean
spacers are your only option to clearn the brakes. as for guard roll depends if you need it once wheels are on.. i think you might get away with it if you put a smaller tyre 275 is farkn huge dude.. ive got 265 on a 10" and thats to much.. try a 245/255 u can even go 235 but that'd be fair stretch'd also spacers all round is not something i'd want to drive around on i hate them depending how much its not clearing by u might get away with a small slip on spacer of a couple mm.. just a thought
better advice sell them and get something with a better offset.. but if u dont do this give the above ago a post pics of result :(
lol blags.. saw u last night cruising through t/c wheels looked toughhhhh!
so with 275s the right rear fitted fine, and the left didnt >.> so light guard roll at the left rear and it was sorted. the front will be running an 8mm slip spacer and longer studs, with a touch of camber. will test drive after spacers and see if it needs a guard roll. rear looks great atm, cant wait to get em on all round :(
235 on 10" is fair stretch i had it..
batak - pizza hut called they want their pizza slicers back
sean put the wheels up for sale its really the best bet trust me u dont want to be running on spacers front and rear its shit, voids ur insurance (not that that's the major problem) and will drive like balls.
i dont think disk type matters much on cr kai's? just re reading above to.. u sure 8mm is enough that will only take ur offset to +30 still pretty high
im not running spacers on the rear... not sure where you got that from
and yes at the front. 8mm clears the brakes. 3mm didnt, 5mm didnt, 3mm+5mm (just to test) fitted and obv 10mm did. so a single 8mm will work and im happy to do that after fitting longer studs..
Skyline model = R32 GTR
Wheel Brand = Work XD9
Wheel diameter = 18"
Wheel width = 10"
Wheel offset = +18
Wheel weight = ??
Wheel + Tyre = ??
Tyre Brand = Falken RT615 Azenis Semi Slicks
Tyre size = 275/35/18
Brake rotors = Vspec II Brembos/Rotors
Modifications to fit = Front - None. Rear - lipped gaurds
nice offset.... will require camber OR flare, but not both
personally i'd go flare and keep the rears on the road :D
changing to +15 17x9 and +18 17x9. due to issue with brake clearance on the front (silly ap calipers)
running +23 9inch atm wonder how it go with the +18
here is what it looks with a 8mm split on so +15 front
edit: with my front bar on
Note: R33 gts-t with stock front guards no rolling
Edited by Kaido_RR
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
