gangster rims looks sexy as pics when on pls :blink:
will do buddy next week ill have my tyres and ill post the pics in my build thread
there not shiny but, the flash made them come out that color, they r lambrghini satin black :D
specs takz? an get a low jack man it'll change your life
18x10 +13 (5mm spacer to clear brakes)
need to work the front guards abit
got some rims for the rear coming from Japan which is going to be fun to fit
impulse buy of the 18x10.5-9
also wanted to do something extreme with the car, i like a little mexican over flush
my front guards are also munched so i could look into 20mm wider front guards if i need a more flush fitment of the 18x10+13
Yer that's huge for the front!! You need flare and huge camber if you decide to lower your car!
As for the rear, that's just ridiculous!! I just ordered 18x10.5 +15 and may need a flare... Dunno what your planning on doing! Loll
i needed to flare for 9.5+25 and the fitment i wanted... lol
btw there is a dude on here that has even wider wheels stuck under stock metal :P
i'll find a pic... brb
specs look right epic dish, but i rkn itd be hanging out at least an inch if u got proper shot down the line, looks good but yeh possibly bit mexican me thinks plus to much guard work ceeeeeeebz
Just a quick question for you offset nuts lol
I'm looking to get a full set of xt7s for a 32 gtst. Would 17x8 front 17x9 +28 sit
Flush all round? or what offset should I be optin for? Stock 32 gtst calipers/brakes all round.
Cheers :)
alex - according to those specs, those wheels should sit or are sitting ~50mm further out than your wheels atm, doesnt look it... what you think?
yeh your right i just ran it on offset calc no chance its 50mm further out that would be feckin heapsssssssssssssssssss
it's 60mm more than mine... easily beleivable.... think about it...
30mm in the flare and another 30 past the guard... a titch more camber... easy
dont forget my guards are already an inch further out from pumping, and if i flared them that much...... hmmmmmmmmm
tempting... ffffffuuuuuuuuuuuuuu
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
