GOT SOME NEW RIMS NOW
18x9.5 +15 te37s
rears will fit sweet (i think perfectly flush)
fronts will stick out about an inch i think so gonna dial in some camber and some stretch and see where we go from there hahaha
Roll the guards perfectly flat with some Cusco camber arms maxed in and they'll fit with ease :)
http://i33.photobucket.com/albums/d85/anml...rx/S6300027.jpg
WHEELS IN THE PICTURE ARE 17=8+5 FRONTS WITH A 215 40 REARS ARE 17=9+10 WITH A 215 40 work vs-mx
OLD WHEELS ON MY 32 KINDA MISS EM ....
ANYWAYS GOT A BIT OF A WHEELS PROBLEM FELLAS RUNNING 16=8-4 rears sit fine atm ...but the fronts arent clearing the brakes .so i put a 5mm slip on on the hub but thene the wheel sits off the hub! (danger!!!) cant put a bolt on on because it sits out a bit as is ...
the wheels have a steel insert was thiknig bout pressing them out and running a SHANKED STYLE WHEEL NUT (HOLDEN ,TOYOTA STYLE)
THAT WAY I CAN RUN THE SPACER TO CLEAR THE BRAKES .AND JUST HAVE A LITTLE MORE PEACE OF MIND AND SUPPORT ON THE WHEELS BTW THE SPACERS ARE 8MM SLIP ON ! ANY SUGGESTIONS WOULD BE APPRECIATED CHEERS FELLAS ..PICS WANTS THERE ALL ON
Edited by talky
pic dont work.
wouldnt bolt on spacers solve your issue as you will have new studs?
asi stted in my previous post ..cannot use bolt on wheel spacers as that will make them 8-20 and will sit mexcian as .so im trying to get around it ...but dont really wanna remove the inserts! but might have to
without looking i'm gonna guess this will be a pic of superlights on a 31
speak to jezzaGTR as he has the same setup (if i'm correct)
hey mate nah its a 32 4 door thought id try something diffrent with the 16s and yer there superlights lol.....so im just trying to get em to work properly arghhh
5mm slip on should make it impossible to put the wheel on..
roll fronts + camber?
or
flare?
easiest option sounds like what u suggested..
mmm its already got a lil flare and i dont wanna the front look stupid compared to the back man mmmm ill see wot happens wene i remove these bloody insetrts cheers man
hey all got me new rimz on work vs-xx dont look to bad
Skyline model = r33
Wheel diameter = 18
Wheel width = fronts 9,rears 10
Wheel offset = fronts +30 with 15mm spacers, rears +25
Tyre size = fronts 225,40 rears 235,40
Modifications to fit = none as yet, fronts scub a real lil bit just going to pull them out a lil bit
yeah they are 9inch rim +30 and 15mm spacers so yeah would be +15
im going to pull the inner guards out and pull the guards out so ill have planty of room
and yeah looks mint niskid CHEA BOI
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
