Skyline model = 1998 R34 GT-t
Wheel model = Blitz (not sure what model exactly, all I know is that they are 3-piece, and 5 spoke)
Wheel diameter = 18
Wheel width = Front 8.5, Rear 9.5
Wheel offset = Not entirely sure, picture attached though
Tyre size = Front 245/40, Rear 265/35
Modifications to fit = Again, not sure (was on the car when I got it...)
Well, that was my OLD set up (accident = damaged wheels = need to buy a new set!)
Which brings me to me to a question!
Getting some Enkei RP03s, and looking at the following:
Fronts - 18 x 8.5, +30
Rears - 18 x 9, + 18
Any thought on whether this will work?
There is a 18 x 10, +22 option aswell.
Any thoughts appreciated!
Edited by James34
Go the 9+18 all round
Was thinking that. Would there be any issues with this on the fronts? (i.e. any modifications required, wheels poking out etc)
Don't think there would be any issue with the rears...
So im considering getting some work xd9s for my 33 gtst its at stock height atm
but i plan on getting coilovers first to lower it a bit,
just wondering what the xd9s in 18x8 + 28, and 18 x 9 + 20/30 would sit like
on the car, and if theres much gaurd work to be done, i dont mind rolling but not too
keen on the flaring, dont really like how it looks on 33 guards.
and not too sure i want to go 18 x9, 18 x 10 which ive seen most people getting
xd9's look best in
17x9.5 + 17 front 18x10 + 18 rear
the design of xd9's really need the biggest sizes for the bigger lip to look good.
you could do this without flaring the guards. you will need to pump them a little or use camber.
would probably run 235' fr and 245 r
Hey everyone just wanna quickly figure out if a set of wheels will fit my car without too much scrubbing..
They are 17x8 & 17x9 work cr Kai's with +38 offset..
My car is pretty low with teins coil overs and I'm running r32 gtr rims with no scrubbing at all any Ideas if these ones above will scrub or will I need to modify the guards?
Cheers
Looking at new wheels for my Gtt, Im putting a gtr front end on, What would be best for the front? Would 17x9 +22 all round suit or would if be better to get 18's to fill the guards? x9 +22 is fine on the rear? Car is not stupid low just on legal height.
Stupid low is way cool. :domokun:
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
