Looking at getting a set of work emotion kiwamis for my r34 25GT
currently sitting stock height with stock wheels etc.
The size of the Kiwami sets I'm looking at are
Front: 18x8.5 +30 offset
Rear: 18x9.5 +38 offset
I'm looking at putting them on without any or with little modifications as possible.
yeah they should fit well. Might rub a tiny bit on the front splash guards with suspension movement n at full lock. but all good.
However, thye are going to make ur can look a bit like its on stilts. So when the time comes you want to lower it with some coilovers you will need to roll the lip on your read arches.
Again, piece of piss n nothing to worry about.
nah you will defaintely be able to get them to fit.
The front guard rub isnt a problem n rolling/cutting the rear lip is a piece of piss. Iv got 18x9.5+38 with a 275width tyre on the rear of my R33 GTST and it fits easily while lowered and only .5 degree of camber, I only needed to cut out the lip on the rear...
fronts are 18x8.5+38 with a 235 tyre. They dont scrub unless really pushed in a 180 turn. Urs will sit 8mm further out than mine which is really nothing but it will slightly increase how much they may scrub on the splash gaurds.
Also R34's are rumoured to have the slightest bit more room in the guards than an R33. never heard this confirmed tho..
the only issue you need to confirm is that these rims are designed to clear the calipers on a skyline, if they do then ur sweet.
Edited by jjman
Anyone have any thoughts on the below wheel specs for an R33 GTST that will be sitting at, or just below legal height?
Varrstoen 2.2.1
Front Rims: 18x9.5 +34 / Front Tyres: 235 (Wanted 9" width for the front wheels, but seems Varrstoen Australia don't offer that width for 18")
Rear Rims: 18x9.5 +30 / Rear Tyres: 255 or 265
Anyone had experience with or seen this spec of Varrstoen wheels fitted to an R33? I'm not going to roll the guards at this stage, and i'm also not a fan of stretched tyres. I don't mind a little bit of scrub (as a worst case scenario) so long as my tyres aren't getting chewed out.
I've gone through this thread, and have a rough idea of what fits an R33 GTST and what doesn't, but I'd like to be fairly sure before I commit to buying wheels, so any thoughts or advice will be appreciated.
If the consensus is that they won't fit without some issue, then i'll probably end up going with Rota grids, as they seem to offer a more suitable variety of sizes & offsets. Also have better customer service than Varrstoen... I've messaged Varrstoen 3 times now (once through the website, and twice on ebay) and no response as yet :)
I should also add, the look i'm going for is wheels flush with guard, I'm not a big fan of protrusion, or 'phat stance' (especially on a GTST, it just doesn't work..). I just want something sensible, and that won't chew out tyres if my car is set at a bit lower than legal.
Don't mind having a bit of negative camber either, probably -1.5 maximum though.
Edited by Chainfire
Varrstoen 2.2.1
Dude that seems like a fairly safe fitment. It will be close to flush, but more inset then poke, which I think is what you are going for. 235 on 9.5 will offer a fair amount of stretch, but it will remove most of the scrubbing issues you may have. Why are you going to run 255's on the rears? You MAY just scrub on full lock, but you shouldn't while driving unless you hit a canyon. I would say roll your guards (for the sake of 1 hour and $100, so worth it in the long run), and no need to run camber.. If you want to run camber, I suggest a more aggressive offset.
I have seen a gtst with 18x9+22 and they poked by about 5mm on the fronts, and rears were inset slightly. If you were to run 255/265 on your rears (as my friend was running heavy stretch) then you have chosen what I believe to be the right offset. You seem to have done your research and I applaud you. Have fun with your fitment, and make sure you post pictures.
Edited by voncina
Varrstoen 2.2.1
Why +34 on the front? You can easily go +30 with a 235/30/18, it won't hit the guard at all and it won't have poke. Ideally you'd want 9" +25 front with 235/40 (v little stretch) and 10" +35 rear (with 265/30/18). Or 9" +25 front and rear.
It's a shame the Varrstoen 2.2.1's aren't available in 8.5 or 9", I really want to avoid stretch as much as possible, I don't mind it too much, so long as the tyre atleast pushes up firmly against the lip of the rim. Would prefer the tyre sidewalls to look similar front to back as well. Oh well, I may have to settle with Rota's.
255's is what I'm using now on my current rims (17" G.max energy's), there's no reason why I can't use 265, other than not knowing if they will rub or not. I am actually picking up the car from panel and paint shop today, I was considering getting them to roll the guards while they were doing the respray, but I also have to take the car over the pits, so thought it best to leave that for now (just in case).
Thanks for the advice and comments, I appreciate it :)
My front fenders seem to like eating my tyres with my current setup (need to confirm the width and tyre size on my current wheels) I don't want to go too close to limits, and risk having more problems and ruining more expensive tyres. Have already spent way too much on this car :P
I would prefer 9" fronts, so I may have to go with the Rota's to get that size.
Thanks for the advice guys, I will be sure to post up pics and results when I go ahead with this.
Hey guys been after a set of wheels ATM have read few pages of the thread n haven't foud what I needed all 18"s but in looking at 17"
I want to run 17x8 + 30 and 17x9+35 on a bone stock r34 gtt will I have any problems with that sort of fitment or Should it be alright?
Edited by SS-
Absolutely no problems at all ever with that fitment. You won't even need rolled guards. That will be no stance, no poke, no dish or concave. It will be very uninteresting in my opinion, but hey, it's your car.
Ohhh I see yeah i just wanted something cheap for now cause one my wheels are slightly buckled while I save for superlaps :)
And also the offsets are the other way around! Any difference or not really?thanks for the quick response
And what offset wpuld have abit of concave for the rears for drifteks?
Sorry noob here :)
Edited by SS-
Sorry noob here :)
Yeah mine are buckled as well, I have just been dealing with it for like 6 months haha. Do a stand still on the buckled rim and it will generally shave itself down to a flat point. Wastes rubber, but makes the ride more comfortable. I do have rims on order though.
You can still get away with that offsets reverse and SHOULDN'T have any issues. The only issue you MAY have is with 9's on the front with such a shitty offset, it may potentially rub on the suspension, and on full lock it may scrub on the guard. Just running through my little file on 34 offsets, no one that I can see so far has run a 9 with a high offset in the fronts. You are better off having the thinner rim on the front as that is the wheel that does the turning, and will be the one to give you issues.
If you want a decent, safe offset on drifteks, assuming you want 17's, and concave, I would go 17x8+20 fronts, 17x9+22 rears. You will most likely need to roll your guards, but that is safe, easy and quick, and will save you hassle in the long run. You won't poke outside the guards, nor too far inset, the only issue you will have will be running 2 different sized rims, and that (if the cop can spot it) will give you a canary. In that case go for 17x8+15 (the lowest offset I can see for drifteks), it won't poke as much, but it will be safer if you fear coppers or don't want defects. That being said, I am running 9.5 fronts and 10.5 rears.
If there is anything else I can help you with, feel free to ask.
And don't worry about being noob, everyone has to start somewhere. If you look back 10 pages you will see me noobing it up as well :)
Edited by voncina
15x10 -26 Superlites 205/50 all round
not the best pictures but once its going again ill get it out and take better ones
I realise not everyone will like it but I do haha
How do your brakes go for clearance under those?
Had a trawl through the thread but couldn't see any photos of a 33 GTST with a 18x10.5 running a 265/35 tyre. May have missed one but does anyone have a photo? Or even a 265/35 on a 10.5 rim not on a car would be helpful!
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
