this is bad advice! Not to mention these are illegal
Because slamming your car and having rims poking 10mm outside the guard isn't.
Hub centralising spacers are fine for daily use - if he told me he was tracking it I would have said no.
clearly you have no idea what is good and bad when it comes to suspension/wheels but im not going to get into an E fight with you...FYI i bolded that section of your quoted text for a reason!
let me know when you have some experience in suspension
How would fitting xxr002 16x8 +0 go for a r32 gtst coupe with 205/50 tyres? I'm wondering how brake clearance would be and if spacers would be needed. I have a guard roller and adjustable camber arms.
brake clearance shouldnt be an issue.....pretty agressive wheels tho! pics when fitted
he's got you there damo... you said illegal, which having rims out of your guards is :P
Won't fit over the front calipers. Knew itd be an issue but was being hopeful lol, time to buy spacers
Thought they would have fit easy, i have 15x10's on my 33 and they fit no problem
Edited by Autumn33
Chaps,
After reading through 115 pages of this thread, I have a bit better of an idea of what sized wheels I should be looking at, but this question is more R34 GTT specific.
I'd like to run
18 x 9 +20 Front (235/40)
18 x 10 + 12 Rear (245/40)
I currently only have Blitz ZZ-R coilovers fitted, but open to comments about what other kind of suspension components needed to run this setup.
Cheers,
Shazza
Chaps,
I'd like to run
Cheers,
Shazza
no issues with the coilovers there. Will need to lip the guards on the rear but the fronts will be no issues. would help if you had rear upper adjustable camber arms but shoud be able to squeeze them in without too much hassles
Hi Frosty,
Thanks for the quick reply. I intend on getting a set of rear camber arms, and front eccentric camber adjustable bolts for adjustment regardless.
Would a 255/40 fit on the 10" wheel on the rear, without much issues?
Cheers,
Shazza
Hi Frosty,
Thanks for the quick reply. I intend on getting a set of Cheers,
Shazza
255 is a big tyre you would want to run a smaller tyre unless you go mexican and run camber but then defeats the purpose anyway. if you look at my signature the one on the right is a R32 with 18x9.5 +12 all round with 235/40 an the GTT is roughly 15mm wider each side in the rear
not at all and only if its more than 25mm ;)
The wheel and tyre must be contained within the body work or mudguards (including any flares) when the
wheels are in the straight ahead position.
http://www.rta.nsw.gov.au/registration/downloads/vsi/vsi09_rev4.pdf
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
