  • 3 weeks later...
Thoughts on this size?
Rota Grids (concave version)
18x10 +35 offset
with 235-40-R18 and 245-40-R18 tyres
With the old tape measure there will be a bit of poke on the front, but im more concerned with what it might
touch under the arches!?!
http://www.willtheyfit.com/index.php?width=215&aspect=55&diameter=16&wheelwidth=6.5&offset=40&width2=235&aspect2=40&diameter2=18&wheelwidth2=10&offset2=35&Submit=Submit
^with the 235 tyres for the front
Cheers guys!
Anyone ever tried machining wheels to reduce the offset from say +22 to +27. This machining would be done on the inside hub where they would take out material to it. Koya Drift Teks and im willin to run a bit of a bigger tyre. If it doesnt work i guess ill have to sell and buy again.
it's possible as that's actually how drifteks are made from the factory, however you will also probably have to cut down the studs to suit.
It's also worth noting that the excess heat from the cutting will compromise the already compromised structural integrity of the rims
Heat shouldn't be an issue, as wheels and brakes do get very hot and Machining can be done slowly.
As joey said you will need shorter studs, or Wheel nuts with open ends. I had 6mm shaved off the front wheels of my beetle years ago....and didnt realise till I went to put them on, that the studs were now too long.
Let the machine shop/Enginbeer decide on how far they are willing to machine them.
Ok guys. Have gotten some Blitz Type 01 wheels in 17x9 with 22p offset. What would be the best width/height tyres to suit a R32 GTS-T standard guards? I believe 245-45 will fit the rears just, as there on atm (flush with the guards) but more concerned with the maximum width for the front, not fussed if the guard needs a little massage but don't want the insides to touch!
Also what tends to be the more popular sizes in 17 inch tyres?
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
