Hey guys new on here ive been looking through here n still unsure of what offset to go, i have a series 1 r33 and i want to put on rota gridRs 18x9.5 but dont want them to hang out too much needs to be legal but still look good, will roll gaurds if need be
Yeah but on an 18x8.5 wheel running street rubber, wouldn't go wider than 255. 245/40/18 would be a good size (can get Sport Maxx for $200 in that size).
Sorry forgot the 8.5 width mentioned.235-245 max or it will look like a muscle car :)
Between +20 and +25, roll all guards and run 235 or 245 tyres
job done
Rays volk gtc with Federal rsr.
Skyline model = 32 gtst
Wheel diameter = 17
Wheel width = 9
Wheel offset = +35
Tyre size = 235 front 255 rear
Modifications to fit = front: minor lip and roll of guard, Rear: rolled guard as hard as i could, just fits.
too big, too wide, tyres too small, too much track increase, cops don't like skylines
if it looks good it's illegal, if it looks shit it's legal... gtst lyf bro
  • Like 1
best size to run on a 9.5... cheapest size so can get better rubber and looks good. still enough for traction and decent rubber choices.
unfortunately while it is WITHIN specs for most decent tyres, it is 1 size too thin for ADR's
Wheel diameter = 17
Wheel width = 9
Wheel offset = +35
On the ground it looks like:
Thanks, the old 32 gtst wing is good. Heavy though.
And im loving the wheels, but i have good tread on my old ones, so im saving the new ones for trackdays and dressing up for friday night etc.
Hi all,
Will these fit 1990 R32 GTR ?
Advan RZ-DF 19x10.5 +15
Badly want 19 inch but happy to
go down in width to 9.5.
Guards already rolled.
Any advise greatly appreciated.
Thanks
http://www.yokohamahk.com/products_detail.php?id=74
Hi all,
Thanks
Tyre size 265/30/19
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
