Hey guys new on here ive been looking through here n still unsure of what offset to go, i have a series 1 r33 and i want to put on rota gridRs 18x9.5 but dont want them to hang out too much needs to be legal but still look good, will roll gaurds if need be
Yeah but on an 18x8.5 wheel running street rubber, wouldn't go wider than 255. 245/40/18 would be a good size (can get Sport Maxx for $200 in that size).
Sorry forgot the 8.5 width mentioned.235-245 max or it will look like a muscle car :)
Between +20 and +25, roll all guards and run 235 or 245 tyres
job done
Rays volk gtc with Federal rsr.
Skyline model = 32 gtst
Wheel diameter = 17
Wheel width = 9
Wheel offset = +35
Tyre size = 235 front 255 rear
Modifications to fit = front: minor lip and roll of guard, Rear: rolled guard as hard as i could, just fits.
too big, too wide, tyres too small, too much track increase, cops don't like skylines
if it looks good it's illegal, if it looks shit it's legal... gtst lyf bro
  • Like 1
best size to run on a 9.5... cheapest size so can get better rubber and looks good. still enough for traction and decent rubber choices.
unfortunately while it is WITHIN specs for most decent tyres, it is 1 size too thin for ADR's
Wheel diameter = 17
Wheel width = 9
Wheel offset = +35
On the ground it looks like:
Thanks, the old 32 gtst wing is good. Heavy though.
And im loving the wheels, but i have good tread on my old ones, so im saving the new ones for trackdays and dressing up for friday night etc.
Hi all,
Will these fit 1990 R32 GTR ?
Advan RZ-DF 19x10.5 +15
Badly want 19 inch but happy to
go down in width to 9.5.
Guards already rolled.
Any advise greatly appreciated.
Thanks
http://www.yokohamahk.com/products_detail.php?id=74
Hi all,
Thanks
Tyre size 265/30/19
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
