hey guys im interested in how much difference the extra capacity will have on turbo lag, and therefore effecting turbo choices
the engine is being rebuilt at the moment and currently the parts goin in are:
Jun 2.7L stroker crank
Jun cosworth forged pistons
Jun forged rods
nismo bearings
Jun oil pump
jun titanium retainers
jun 272 degree cams with 11.35mm lift
jun HD valve springs
Jun cam gears
Jun head studs
Jun big end bolts
sard 1000cc injectors
trust t04 flanged single turbo manifold
autronics SMC and CDI
sard fuel rail
sard adjustable fuel reg
single magnafuel 1000hp fuel pump
msd coils
custom 9L baffled sump
50mm hks external wastegate
oil cooler kit
100mm+ thick jap cooler (still lookin for one)
and now im after what turbo would be suitable for response more than power, and im wanting 500hp at wheels daily and capable of upto around 600hp at wheels for dyno sessions.
im thinking gt30 is too small, and same with gt35
so gt40, gt42 or new garret t04z with a 1.06 exhuast housing?
prefer the garret choices as the hks stuff etc is bloody pricey and ill be changing to a larger one in the future anyway to see what it can really do :P
any info appreciated
Brad
The capacity increase alone without taking into account the other planned mods aint going to do a significant amount in the way of reducing lag.
Going to 2.7 from 2.6 is a displacement increase of ~4%. So in theory a turbo would operate ~4% earlier in the rev range to an equivalent 2.6.
Are u using an N1 block as well. The 2.7lt kit is for crazy revs most drag and dyno 2.7lts rev out to 11000rpm witch is were you get the extra power band.
nope normal block :P
600hp isnt excessive on a rb26 block is it? 10 000rpm redline is the plan ;)
Hi Brad heard about this project and have done a bit of digging.The same motor just been built in perth and has twin 2530's making 500hp at 16psi with awesome response great carto drive by all accounts,here comes my point another gtr rb26 with 87mm pistons making it nearly 2.7 runs a single garret to4z with the 81 or 86 housing has the same power curve and response but running 20psi at 520hp with a bit more room to move.For my money i would be going the garret with the same housing dont make the mistake of going to big as they make good hp but are no fun on the street.
cheers
Danny
MMMM, this list of parts looks a lot like "4 Door Gtr's" old parts list he had for sale!
Anyway, I would look into the GT40 or the T04Z. Ben from Racepace runs the GT42R on his 3Ltr track GTR. But correct me if I'm wrong. With your camshaft set up at 11.35 lift generally means your car will not be that streetable. I spoke to 4 Door Gtr on the phone about his set up and he said it was far too lumpy for the street.
If you really want to know about which turbo is best suited for your set up give Lance at Croydon Racing a call. Try their website too (www.croydonracingdevelopments.com).
Hope this helps in some way!
500 HP daily and 600 for dyno runs and response over power - from 2700cc's .
The Americans have played with a system of a centrifugal supercharger blowing through an exhaust driven turbocharger with good results but it needs a bit of thought put into by pass systems . I don't know if there's any other way of making it streetable without more capacity - I would have given serious thought to the RB30/31 conversion as I'm told 600HP is a walk in the park with suitable hardware . The GT40R would do well on a street driven RB31 Dyno Queen . These are not common yet but will get some details .
Cheers A .
nope normal block
i hope not im in the same boat but with stock crank. i just thought with a list like that a N1 block as well. That way when the bug bites u can do something similer to the car in HPI 56
His is a custom RacePace turbo (1000hp) that he made to his own specs, punches out well over 600rwhp. You cant compare anything to that car. League of its own.
Anyhow, GT35 is the way to go. I doubt you'll need much bigger.
It'll be extremely streetable (with smaller cams) and still give you the mumbo around the 500hp mark, probably a bit less... 460-480 if you talk to the right people and get a decent turbo made from the GT35 options.
On some good fuel for a few dyno runs with big boost you'll get close to the 600hp mark :P but probably not quite. Again... 570-580 approx at a guess.
If you drop your expectations by 30hp (22kw) then you'll get into very do-able territory IMO
And yeah, as others, why monster cams? You certainly dont need it, not do you need 10,000rpm to make these numbers :P
geez ide love to have that engine to play with :cheers:
in my opinion the best response/power combo with a built engine would be twin HKS GT-RS, capable of 400-500rwkw and can handle upto 2bar without a problem
thats assuming you want twins, single probably the new (well new-ish) HKS TO4Z
R31Nismoid READ what I wrote. I recommended the GT40 and the T04Z. I merely stated that Ben ran a GT42R and at no point did I compare Ben's set up to StageZilla's.
According to Ben the GT35R is a fairly small turbo for a standard capacity RB26 so using it on a 2.7 ????? :cheers: . My advice; do the research ask someone in the know! Call a reputable performance center. There are places that make custom turbo's for specific set ups.
its hardly what most would get when "buying a GT42" as its totally different to what comes off the shelf :cheers:
yeah the 35 isnt the biggest you can run on a 2.7... but its personal thoughts i express there if he drops his power aims.
If he doesnt then your gonna need bigger.
Also to note, JAGR33 made 370rwkw with the twin Trust turbos.
Thats pretty mad for pulp and 20psi
okay guys cheers for all the info and comments :D
well i have bought a combo of stuff and the jun stroker kit together with the cams, so i thought stuff it ill get cams which wont be a big drama as i only drive it a few hundred kays a week as i have a work car :)
i want a combo ready for future when i wanna see what it can do with a monster turbo like gt45 or something and the engine combo is rated at 750-800hp at wheels from the JUN head guy. :)
the combo was goin on a demo car for the same shop that did the r34 and the deal didnt work out and i got lucky ;)
also i got the trust single turbo manifold with the combo and it looks awesome so i wanna try a big single :)
im gonna go hks t04z in the future, but ill most likely try the garret t04z 0.86 first and see what it can do :D
the jun stroker kit is made for reving not capacity thats why its only 2.7L which i presume is better for circuit work with the large rpm range :)
turbo should make boost by 4000rpm i reckon and revving to 10 000rpm its a bloody decent power band rather than a 3L doin 3000rpm to 7000rpm or about that :)
each to their own :cheers:
Brad
post the results :cheers:
will do and maybe might try some smaller low mounts again in the future if its too laggy, but i like the idea of a roomier engine bay and easy to work on :D
cheers
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
