Any chance of some pics?. I just bought another head unit to replace the pioneer carrozzeria unit (spaghetti City), and the new unit has all the wires connected to a plug. It sounds like this could be just the thing for an easy fit. That is apart from pulling out the spaghetti for the GPS, Satnav, DVD player, TV, Aerials etc :-(
Check my first post, I have updated with model number and picture. Just cut the brown connectors off and leave the white ones on there. The factory wires will click into the white connectors, and the coloured wires will match up with any aftermarket radio loom as they all use the same colour system. Just solder them on. :kiss:
Note .. This was for the standard double DIN radio and CD player, not sure about the Navi/TV units.
Does anyone know if the stock screens in the s2 stags operate in "ntsc" or "pal"? it's a tuf one i know. the local installer is going to do a dummy install on the weekend to see if a dvd head unit will work on the stock screen
Japan uses NTSC, so knowing that and the previous experience of other Stagea owners, I'm going with that. Quite a few products use a PAL to NTSC converter built-in, anyway...
NTSC it is.
I have wondered about the units that read PAL and NTSC discs as a lot do, I would be more interested in the signal they output? If you could get something that output NTSC as an option that would work.
I have checked my Factory screen by pluging in a a PAL MiniDV camera and the results where as expected, no good. The NTSC reversing camera works a treat though...
Cheers
Luke
  • 3 weeks later...
When I installed my stereo, the surround for the head unit refused to go on either behind or in front of the surround, and now that I've bought a DIN-sized gauge holder for my car, I'm having the same issues...
Has anyone noticed that the actual dash piece is slightly smaller than the regular DIN size? Or is it just me?
yeah - because its the facia. The actual DIN is the steel cradle that supports it all. I noticed the last time I had my player out that someone had very carefully relieved the edges of the face with something.
Got a Dremel and a steady hand? I don't think you have to take much off. This was the same with the old in dash radios for XD falcons
yeah, but it's kinda annoying that the stereo fits but the surround doesn't, and the same with the guage holder...
Don't have a dremel, but The Grumpy Old Man has about a million different files lying around which should suit the purpose.
get on ebay and buy and "iubi" 60gb hold all ur music n heaps of movies plugs into the front of ur Xanavi screen,i bought one with a 100gb laptop hdd in it. ive got about 10gb of music the rest are ntsc movies n TV episodes ive downloaded. best thing ever, watch all of heroes in high definition heaps of family guy, top gear, scrubs, my name is earl, futurama.
  • 1 month later...
Alrighty i have a few questions with regards my head unit install any opinions appreciated.  First thing 'exitSTAGEAright' LEGEND of a man the aeropro adapter made things so easy. Im actually removing my head unit from my old car and into my 260rs and the plugs that were soldered onto it were the same brand accept i paid some prick $70 bucks to install it... jackass. Anyway i have all that sorted out as in the adapter soldered to my head unit no problems. Oh and by the way for all who are looking to buy these i called JB HIFI and they told me they weren't stocking these sort of adaptors anymore. Autobarn had them instock and said they would continue to. Anyway movin on
I bought the car without a head unit so as i recieved it with all the plugs just hangin out or tucked in the consol.
Picture 1 = stereoplugs.jpg - These are the 2 stereo conectors and the arial connector?
Picutre 2= unknownplugs1.jpg - The left you can see seems to connect with the larger stereo connection but the
e is only two
small cables connecting this socket into the main loom. The two smaller plugs on the right are connected to the main plug on the l
ft. i haven't the faintest idea what these are for... any ideas?
Picture 3= unkwonplugs2.jpg - This bown plug sits quite close to the main loom but again i have no idea what
ts for. clues?
Thanks guys i haven't been brave enough to just plug the head unit in to see if it works yet just wanted a bit of knowledge first.
Cheers guys
Edited by MyStag260
I *might* be pulling my dash apart again to connect (at least some of) my gauges, so I'll see if there are any plugs in there that look like that.
I wish I had a laptop so I could take it out to the garage, it would make it quite a bit easier. Saves me running all the way through the house back to my room, then out again to the car.
Has anyone relocated their air cond/heater controls in their stag?
i just want to move it from the top to the bottom of my din slots..
they make extension cables with plugs in japan but if it's not a hard job i may as well just make it myself...
Picutre 2= unknownplugs1.jpg - The left you can see seems to connect with the larger stereo connection but there is only two
small cables connecting this socket into the main loom. The two smaller plugs on the right are connected to the main plug on the left. i haven't the faintest idea what these are for... any ideas?
Picture 3= unkwonplugs2.jpg - This bown plug sits quite close to the main loom but again i have no idea what its for. clues?
Cheers guys
Looks like the plugs that I have, but most of mine are plugged into something...
The brown one, I am pretty sure is just hanging unplugged and you will find a few of these under the dash area, I assume they were used during manufacture to test systems and ensure everything is working.
The other larger ones look like the climate control plugs but I have the factory Navi touchscreen unit so they might not all be used with the single din climate control unit, so that might be why you have so many spare?
The plug with the grey insulated wires running into it looks like the sat nav connections I have in mine.
Nissan would have run looms to cover all options during manufacture, so most cars would have some wiring that was never used for anything.
I hope that helps! I'd say if everything is working as it should then they are just extra looms that were not needed. All looks very familiar and factory but I could only be 100% if I pulled my dash unit out and looked...
Cheers
Luke
Jase, keep me informed as well, if you would: I have want to do the same thing...
Thanks mate,
Micah
Micah, worst case scenario I will get a mate to post some over from Japan. They are a bit on the pricey side (for a bit of wire and some plugs), thats why I'm just asking if anyone has done it themselves.
you dont need extension cables
it reaches
all you have ot do is drill new holes in teh metal brackets since the hole alignment is different
i was going to do it, but hten didnt have all the tools i needed, so i never got around to it
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
