  • 1 year later...
I just installed a cd/dvd/tv unit as well and I am wanting to hook up a reversing camera. Does anyone know which wire I need to attach the unit to to switch to the camera when I hit reverse?
Cheers
i powered my cam from the reverse lights in the rear door as i mounted mine just under the handle.
cool cheers, I was thinking I might put it there. I can use the reverse light wire at the rear to power the camera. However what about the trigger wire from the head unit? Where abouts is the reverse light wire in the dash? Is it under the centre console? Which color? (I haven't had a look yet, so it may be obvious to me when I take it out next. I just thought someone may be able to save me the trouble)
Thanks again
:P
  • 2 months later...
Can i get some kind of confirmation on the stereo wiring for the S2? Or if anyone knows of a adaptor kit?
I ask as i am lookign at a 2 din hole with two blank connectors, and i know i have 6 speakers (2 pillar tweeters).
Thanks in advance!
just a question for everyone in here who has taken there dash apart a few times, does anyone else have spastic cup holders? what did you do to fix them? mine sort of work but they hang to one side and look funy.
Thanks in advance!
You will only have 4 pairs of speaker wires, the A pillar speakers are "splits" with the front door speakers.
Has anyone put a double din head unit into a C34? Just wondering if there are any issues with it.
I've done it . Absolutely no probs, just follow the DIY. Get a plug to suit from JB, cut and solder.
Edited by 66yostagea
Thanks to STAGE-A for the wiring
12V ------- Brown with white stripe
Ignition -------- light blue with yellow stripe
Lights -------- Red with blue stripe
Earth -------- Just use the stereo metal brackets
and heres the speaker connection wires (stagea s1 at least)
left front ---- blue (+) black with white stripe (-)
right front ---- brown (+) black with red stripe (-)
left rear ----- mint green (+) black with yellow stripe (-)
right rear ---- orange (+) black with pink stripe (-)
On my S2, i found the RL & RR polarity was reversed to the above stated. and i also had two spare wires :)
  • 2 months later...
installed a new HU on the weekend
bought the Aerpro antenna adaptor, and found i got good reception even without combining both the antenna's
spliced into the black/yellow wire, and it seems radio reception is fine, haven't tested extensively yet
ran the ipod cable into the centre console, and a bluetooth mic into the exmpty switch next to the rear demister
lots of fun to work with. . . not!
  • 3 months later...
Quick question I need clarification on...
Will an S1 Xanavi unit be a direct swap into an S2 with the Factory CD/cas unit?
I believe it will. But why would you want the Xanavi unit anyhow?
just to let everyone know, there is probably an adaptor from aerpro that will plug into the stock harness
i dont know what the part number is but my r32 took the same part as a gq patrol which is about the same age so i would suspect that an adaptor is available to prevent having to cut and solder and also save time
Interesting...so Does the S2 car that has xanavi use the same looms/wires/sockets or whatever for air-conditioning... as one that didn't come stock with the xanavi unit?
No it does not.
One would require something like this: http://page5.auctions.yahoo.co.jp/jp/auction/e93993162
Ahh bugger. I'll be needing to buy one of them. Could you tell me the name of it so i know what to search for when it comes time.. please. haha
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
