semi-slicks
Nitto 555R's are THE best you can get, no doubt. All the big names use them, especially Veilside. However, as far as i know they're not actually legal in Australia, so therefore you'd have to have connections to get hold of some. They're the best semi-slick to get, if you can get hold of them.
https://www.sau.com.au/forums/topic/8536-semi-slicks/#findComment-125529
Nitto's are one of the only drag specialised R comp that i know of. The others are made for track work, simple as that. Ideally if you want to get good drag times, get 2 cheap rims and a pair of fully slick tyres.
R comps wont provide you with that much extra, compared to a pair of full slicks on the back. And the slicks would probably cost less than 4 R comps.
I once saw a HSV ute with Potenza 540's on it down at the Motorplex, he was doing burnouts before each run, over heating the tyres and running the same times as he was on street tyres. They didnt last very long either.
Red17
https://www.sau.com.au/forums/topic/8536-semi-slicks/#findComment-126766
Go & compare the price difference btw Nitto's & RE540S's! HUGE difference & not in the Nitto's favour.
RE540S's cost me $1180 balanced & fitted (235/45/17 - 255/40/17)
Yokohama A032R's & Dunlop D01J's were both considerably more expensive, but compared to Nitto's they were dirt-cheap!!!
Having physically compared the Nitto NT555 & RE540S I can say they are pretty much the same in tread softness, it's the soft sidewall that gives the Nitto its drag abilities. Trust me when I say the RE540S is VERY grippy in a straight line for a cornering tyre. If you want to run decent 1/4 times on a street legal tyre & don't want to spent big $$$ give any of the A032R, D01J, RE540S rubber a go.
Doing big burnouts on the RE540S isn't needed, & as the HSV owner @ the 'plex proved it'll ruin any advantage the soft treaded RE540S gives.
The problem I see in running with full slicks is it's no longer a *street* set-up (i.e. HPI challenge) IMHO
Here's a thread I started a while back - http://www.skylinesaustralia.com/forums/sh...ighlight=RE540S
https://www.sau.com.au/forums/topic/8536-semi-slicks/#findComment-127856
Ahh yes, i guess thats the problem, its the old racing rules they catch ya with. I figured the guy just wanted to get the best time possible.
In that case, certainly, treating a set of R comps properly is no doubt ALOT better than street tyres.
And youre right, the Nitto's are ridiculously priced :D
Red17
https://www.sau.com.au/forums/topic/8536-semi-slicks/#findComment-127894
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
