  • Replies 714
Posted Images
Gidday Mafia, this is Garys recommended settings which you can get with this kit
For the street here are my recommended settings;
Front Camber -1.00
Front Caster +7.00 (slightly more on the left to offset the drift to the gutter)
Front Toe 0.00
Rear Camber -0.5
Rear Toe 2.00 mm in on each side
For the track;
Front Camber -2.50
Front Caster +7.00 (or more if you can get it)
Front Toe 2 mm out each side
Rear Camber -1.25
As you can see the big change is camber, what most the guys do (me included) is to use the Whiteline camber kits to adjust the camber when they have the car jacked up to put the track tyres on. Just get the wheel aligner to mark the amount of rotation you need for the 2 settings. Then you simply rotate the offset bush for the right amount (track or road).
The Group Buy Bilsteins have additional circlip grooves added so you can set the height you want before you fit them. There are 6 grooves 8 mm apart and I can tell you the height that you will get from each groove. Keep in mind that GTSTs handle best around 350 mm front and 340 mm rear (centre of wheel to guard).
thanks so much. I'm going to fit the shocks, and then get pedders here in mackay to install the castor and camber kits with these settings.
Front Castor Kits. Are they adjustable or preset at 7 deg?? Will they only work with the Bilsteins or can they be used in conjunction with stock or other coilovers?
Work with any brand of shocks, springs, whatever.
Every car is different, but somewhere between 6 degrees and 7 degrees is the normal result.
Thats a bit extreme isnt it?
Nope, 8 mm eacd side is extreme
:) cheers :banana:
Edited by Sydneykid
The current out of stock situation with R33GTST springs at Whiteline is expected to be fixed by late next week.
:D cheers :D
how much would it cost just for the bushes out of this kit?
Prices are on page 1 (the front camber kit has had a price reduction);
Nissan Skyline
R33GTST
KCA331 Caster Kit $110.00
KCA348 Front Camber kit $183.00
KCA347 Rear Camber Kit $123.00
KCA349 Rear Subframe alignment kit $105.00
Freight $20.00
Sub Total $541.00
:( cheers :no:
I'm after some subframe alignment bushes, just one question.......... How easy are they to put in, do i need any special tools and does the suframe have to come right out or can i get away with just dropping it down on a jack and slipping them in?
Thanks
Aaron
Thanks
Aaron
Hi Aaron, installing the rear subframe alignment bushes takes about 20 minutes, it's an easy DIY job and no "special" tools are required.
:) Cheers :)
Hi Gary,
I am interested in the group buy and have a few questions:
I drive a R33 GTST sedan, currently I believe they sit on some aftermarket KYB shocks that came with the car. Measurement from centre of wheel to guard is 365mm.
Current ride quality is pretty bad, as I belive the shocks are on the way out, as rebound is becoming non existant.
Anway my questions are:
1. If I was to purchase the Bilstein/Whiteline kit which items will I need or exclude from the group buy set, given that I have already installed:
- Noltec upper outer front control arm bushes with adjustables
- Noltec front radius rod bushes with adjustables
2. A stupid question: At the lowest height setting, from my understanding, this is achieved with the 3 circlip grooves 8mm apart =24mm lower from the standard 350mm, how will the ride be? I gather this correlates to the set-up of the whole suspension?
Thanks for your time.
Hi Gary,
PM sent
:thumbsup: cheers :)
well I will be getting a set of swaybars off you Gary for my R33 in the next few weeks
How long am I looking at after payment has been made to you.
also what would you recommend in the way of sway bars for a street R33? and did I need any other thing to fit these to the car?
I take it this will stop a heap of body roll in the car????? and stiffen up the backend .
everyone says it is a good mod for the R33 in the supension department.
how much would be looking at for both bars (fixed/adjustable)
cheers
Fixed or adjustable ones.
cheers
PM sent
:D cheers :P
cheers
Hey SK,
interested same as above delivered to WA
Are the swaybars you offer modified from the whiteline specification?
or are they the same if I order from whiteline?
Interested in the adjustable ones
regards
lukits
Hey SK,
1. interested same as above delivered to WA
2. Are the swaybars you offer modified from the whiteline specification?
3. or are they the same if I order from whiteline?
4. Interested in the adjustable ones
regards
lukits
Suggestions follow;
1. No problem, orders over $500 aree freight free to anywhere in Australia
2. Yep, they have extra adjustment and on some models unique diameters
3. Nope, you can't buy Group Buy spec bars from anyone else
4. No problems, PM sent with details.
:no: cheers :laugh:
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
