Jamex also delivered the wrong shocks to me the same as SKYKC. As instructed I sent them back, but Jamex refused to accept them.
I guess its buyer beware.
Having paid my money over 2 months ago I am not impressed with this group buy.
I dont know the name of the person I am dealing with - except its 'Gary'. I have been asked to send money to a company Jamex that does not want to identify itself.
I cant really complain as dealing in this manner is asking for trouble and thats what I have.
I urge others to be very careful when dealing in this manner. I accept that others have had great success and given great feedback.
David
Edited by old_man_silvia
  • Replies 714
Posted Images
I ordered my front and rear sway bars and front adjustable castor yesterday - lets hope payment was received :happy:
I just got quoted $742 from my local Fulcrum store. I didnt think it'd be that much to install the whole kit with an alignment. Who else should I try?
David
Just for clarification, I have spoken to David on the phone and sorted the confusion out. He should have his shocks on Tuesday.
:) cheers :(
ouch!! i take it that includes them assembling the shocks too? anyone else care to share how much they paid for installation?
cheers.
$700 is very very steep.
myself and a mate did the springs + shocks along with the pineapples ourselves. it took us a lazy 3 hours. i'm sure most of the users on this forum would have the basic socket, spanner, trolley jack, shifting spanner, axle stands etc. definately something that you could save money on.
most workshops want the car for at minimum the whole day so that they can work on the car between every little job. to me that's more hassle than its worth - since id rather do it myself than wait around for the entire day without a car.
i am still waiting on my front camber bushes which wasnt included in my delivery from jamex and will need a press to get the rest of the babies in. *any idea where the wednesday/thursday delivery is happening gary?
cheers.
##I got a quate from East Coast Suspensions as followes, is that the normal price for installation?
*To fit your springs & shocks , plus front camber & caster kit would cost $450.00.
*To fit the rear camber kit to the upper outer pivot points (ie. in the
upright would cost an additional $135.00.
*For Front & rear wheel alignment ( full adjust ) is $165.00.
So All up to $750
##St George quate for the above for $893
##Nismo quate me $350 for shock installation $400 for caster and camber installation, and $88 for wheel alignment.so all up to $838
##Pedders quate me $450 just to install the shocks,,,I didnt ask for the rest hehehe.
You are looking at around one full day to do everything, so around $400 should cover it.
don't know if this still applies - but i guess it's a good figure to work around
Guys,
Im setting my rride height for 355/345. as per the dust cover and bump stop, not sure where to cut it for it tio suit the ride height. please refer to the picture attached. This pic got it from Garys R33 GTr forum.
thinking of cutting 5mm further down where Gary has indicated 350mm mark?
Hi Gary,
Can you please confirm my order for the f & r sway bars and front adjustable castor?
cheers mate!
Gary,
Still waiting for these shocks to turn up. What is the latest please. Do you have a con note?
David
:P cheers :P
Gary,
David
They were hard to track down, found them yesterday. I should have them tonight and send them to you tomorrow. I will PM you the con note number as soon as I have it.
:) cheers :kiss:
Still waiting on my order....Sent another PM yesterday.
Sorry for the delay, only 1 set of bump stop/dust covers in stock, delivery expected today. If so, they will go out to you tomorrow. I will PM you a con note number as soon as it is issued.
:) cheers :kiss:
Hi Gary,
cheers mate!
Did you order via email or PM? If email, then the response would have gone out by email.
:) cheers :kiss:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
