after 6 years of jealosy and yearning for my liner...i finally got it...but theres 1 problem ...my bloody driveway is too steep...scraped the bottom of the lip when trying to get it down the driveway ...now my baby has to sit out in the cold :)
I think its time to get the construction crew in to fix up the driveway...
anybody know any quick fixes to get the car down a steep drivway?...
if so, where do i get the materials to solve the problem....??
https://www.sau.com.au/forums/topic/85565-i-got-my-car/
Yeh thats what I was going to sugest, planks of wood... work a treat. if they dont work.. then your driveway must be reaaaaaaaaly steep!!
welcome to the car owning side of SAU mate, it was about 4 yrs before I bought my r32 :)
https://www.sau.com.au/forums/topic/85565-i-got-my-car/#findComment-1548968
sledge hammer :)
but in all seriousness, I have to use planks of wood. if you go to your local bunnings, and buy some offcut 2x4 preferreably 2 bits 1m in length, and lay them down in the gutter.
I only drive my car on the weekend, so it'd not too much hassle, but it'd drive me nuts doing it everyday. If you leave em there, some little pricks might take em.
cheers
https://www.sau.com.au/forums/topic/85565-i-got-my-car/#findComment-1549063
buy a sheet of that thick checker plate alluminium (Bunnings Dural has them).
Lay that across the front of your driveway, use a hammer drill to drill into the concrete, and use some bolts to bolt the alluminium down. If council complains, unbolt and remove... Then replace when they're gone... :D
https://www.sau.com.au/forums/topic/85565-i-got-my-car/#findComment-1549525
Thanks for the suggestions guys, ill give the planks of wood a go for now.....its almost impossible to go in on an angle because its such a small driveway, its not the initial gutter im having problems with its the flat bit just before it enters the garage...basically from the gutter its flat, then it goes down on about a 35-40 degree angle then its flat again ..its the bottom section i had probs with...
I'll stick pics up soon, but its pretty much stock looking sII with stock rims ....(next purchase)
https://www.sau.com.au/forums/topic/85565-i-got-my-car/#findComment-1549681
Need to go side way down.. used to happen to my ex-line with 400R front bar everyday (steep driveway). Just remember to let 1 front wheel reach the ground first then the other.
If still impossible, cheapest way is get a long timber and trim it suit ur driveway. I've seen few tyre shops use this way for customers with LOW cars.
https://www.sau.com.au/forums/topic/85565-i-got-my-car/#findComment-1549916
My precious...
Still needs some pretty rims....
I should take it out for a proper fotoshoot when i get them...
Anyway ...thanks for looking ...
ill get a foto of the driveway to explain my dilema properly when theres light...
oh yeah...those halogen lights...is it illegal for me to drive with them on?
https://www.sau.com.au/forums/topic/85565-i-got-my-car/#findComment-1551863
at my old place my parents bought a sedan that was quite low, couldnt get over the edge going down to the driveway, within a couple of weeks they got construction people in, they jackhammered the concrete down and relaid half of the driveway so it was a smooth angle lol
https://www.sau.com.au/forums/topic/85565-i-got-my-car/#findComment-1552129
Huge thread (do a search for Driveway Problems) about driveway problems when I first got my Skyline (well after I lowered it :))... I have one bloody steep driveway and if it weren't for the planks of wood, my front bar would be no more :)
Pros for the wood:
1) They are very very cheap, use offcuts from anywhere
2) Quite light and not too hard to setup
Cons for the wood:
1) Not good in the rain
2) Gets bloody annoying when they start to rot away
3) Depending on your road surface, it will start to destroy itself.
My next plan is to get some steel drainage vents (maybe 2m x 1m) which I can mount on top of the driveway as stated above in a previous post. Not only will this get rid of most of the cons, but will also make a nice addition to my shoddy driveway :D
Just some thoughts...
https://www.sau.com.au/forums/topic/85565-i-got-my-car/#findComment-1564870
Thanks for the suggestions guys, but the real problem isnt entering the driveway from the road, its at the bottom of the driveway. *see attatched* Ive tried reversing it in to no avail.. Close, but no cigar. Anyway, i think the only option is to tear up the driveway and build a new one.
THe red bits on the images indicate where the front would hit if i drove it down front first or reversed it in.
https://www.sau.com.au/forums/topic/85565-i-got-my-car/#findComment-1575619
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
