Hi guys, organising a group buy for H/D Clutch kits for R32-33
This is a special price I'm able to get the clutches at this stage
All Clutch kits are brand new & comes with 12 months warranty on parts
1. Exedy H/D Organic kit incl:
* Exedy H/D Organic clutch plate
* RPM Brass Button Pressure plate
* New Bearings
This kit can handle 240rwkw
$320
2. Exedy Button Kit incl:
* Exedy 5 puk plate
* RPM Pressure Plate
* New Bearings
This kit can handle 300rwkw
$425
Can get clutches for SR20det, CAdet, WRX almost any type of car
Also able to get RDA slotted rotors
my no is 0405-101-901
Marz
Edited by C & B
https://www.sau.com.au/forums/topic/85676-exedy-hd-clutch-kits/
  • Replies 96
Skylines has 2 diferent types of rotors at the front & rear
they are realy good quality rotors & you geting warranty with them as well
1. Front 280od by 24m $200ea
Rear 266od by 8m $210ea
2. Front 296od by 28m $210ea
Rear 297od by 16m $135ea
All front rotors are vented & the rear ones are solid rotors
I'm locted in SE suburbs of Melb
So these are all youneed to replace your current clutch?
Also im in melb when could i pick one up?
Cheers.
Thats corect this all you need to rplace your clutch, it's the whole kit
I have a set with me rite now, give me a buzz anytime you want to come & pick it up
& the organic clutch operates like your normal clutch, the diference is more clamping pressure than a normal H/D clutch kit, so would be prefect for everyday driving & racing at the tracks once in a while
if you more in to drifting & draging the button clutch would be perfect
Can i ask what the RRP is on these kits??? Cause i've been looking at getting an Xteme Clutch and its a fair bit more expensive than this.
Also Whats the clamping pressure like over stock???
Cheers
Cheers
RRP on these clutches is $600+ on a Button Kit & $500+ on a Organic kit, not 100% to be sure
You can use the organic kit on a stock car, will be very useful if you gonna be modding your car down the track as the organic kit can safely handle 240rwkw
if I've not mistaken the clamping pressure would be 30-40% more over a stock clutch
Sorry another quick question, is RPM a brand??? It says RPM pressure plate, is that Exedy as well or is it only the clutch plate that is exedy??
RPM id done by clutch industries, use to be PBR but it's taken over by Australian clutch industries recently
but can get the Daiken pressure plates as well
Daiken owns Exedy as most of you would probably know
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
