I personally think of R33's as low flying blimps... but that's just me and I don't have any technical or scientific reasons why, they are awesome cars... its only crime was that Nissan hired a team of designers to make a very generic design.
my 02 commo ute had koni adjustable front and rear and was 3 inches lower then stock. I had the suspensions guys tune the koni's as appropriate as possible. big wheels and tyres, 500hp. I thought it was the ducks nuts but still found myself hesitant through corners. then I drove my current stock r33 with slightly better rubber and cat back exhaust and thought it handled 50% better then the ute. a week later a owned the skyline and sold then ute. go figure.
Traction control my ass you Holden Bogans. You haven't experienced a corner until you've driven with HICAS ;)
to right. although hicas can have a downside to.... car starts to drift, you try correct it... it trys to correct it..... :lol:
Dunno about the R33, but my Nismo Coil Over equipped R32 GTS-T is DEFINITELY not a boat. Getting out of my dads VX Commodore (FEII suspension, supercharged V6, LSD) into my car makes the commodore feel like an ocean liner. No way in hell am i gonna try and slide that behemoth through a corner. Despite that, I can say the FEII suspension controls the body roll well, and it definitely grips tenaciously during corners. The traction control is horrible though, and you soon learn to start the car and disengage TC in one smooth motion. I wish I could turn HICAS off sometimes. Sorry guys, but not a fan...
My Dads commo isnt all bad, certainly more comfortable than the skyline. The skyline's suspension is very still and feels slightly underdamped over rough roads. But the shear size of the Commodore means I could never own one myself.
Come to think of it, the skyline is a little bigger than I'd like as well... I'd prefer a Lotus Exige (800kgs, 190hp) haha! Now that car can never be called a boat... Except maybe by owners of Arial Atoms (500kgs, 300hp)... And they might be called boats by motorcylists...
So the skyline is not a boat, but it doesn't hold the honour as the most nimble car on the road either. I think it's the balance of power and handling that attracts most with the skyline. You can get a nimbler car, say an MX5, but you will never be as quick in a straight line as a skyline.
My mates R32 has GTR suspension and 17x9 rear and 17x8 front, it handles rediciously well through chicanes and yet is very drivable not being too stiff. I wouldn't dream of wanting to go in a commo through a tight local government chicane at 120Kph, especially if it wasnt at HSV. R32's def arn't boats in my opinion. An R33 GTS auto is getting close to being called a boat though. R34's i wouldnt consider boats they'l outhandle a commodore.. Anyways concluding comodores are the boats, generally, and skylines arn't, generally..
PS:
If they think they are better, the best way to shove it in thier face is to go to a track day and give them a flogging, and say whoever loses pays both the fees. simple - just win
Cheers,
Rhys
:O
Edited by WhatBrake
True :) but it's still fun to have one arm hanging out the window while you're doing it. :)
I've got a R33 GTS-T with standard suspension (bar lowered springs), and yep i'd say it's a bit boat... feels big and heavy, and sways around pretty badly... if I purchased some sway bars, it would be much better.
Either way, I love the car. If a commodore drove like this and cost as little, i'd be driving a commodore :) Thats why the commodore comments don't bother me. If my car feels big and heavy, I hate to imagine what a commodore is like to drive :)
I suspect a track day will make me realise how good / bad the car handles anyway - very hard to get a true indication of it on the street :)
Edited by TommO
yeh but the ute has leaf springs in the rear, and heaps of weight in the front (v8, and light rear). all things being equal the ute is always going to be at a disadvantage
The skyline is a performance car that was designed to handel well (a drivers car) from its initial design. Holdens and Fords were designed as family commuters, (soft and cumfortable and built to the lowest price)then modified slightly (where possible) to handel for a (performance) option.
Driving a Ford is a lot like stearing a boat, turn the wheel and wait a while for it to respond. (based on my experiences in our XF and BA) whilst the holdens are a lot tighter more like a skyline (feedback through the wheel) but both have way too much body roll and dont respond as well through the full range of suspension tavel.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
