Looking for rear springs for my R32GTR - want a spring rate of ~250lbs, 60/61mm ID, free height of around 250mm (?) with tender coils.
What's the difference between the three spring manufacturers?
King 'pro sport' coil springs are 'Hot rolled, oil quenched and tempered', whereas Whiteline race springs are 'chrome cold wound'... what's the go with them?
Questions:
1. will i get away with a shorter spring, say 220mm, with using tenders as well
2. two choices will be
Kings - KPS-042 250mm free height, 250lb
Whiteline - CS61220045 220mm free height, 252lb
are they more or less both the same?
3. do lovells make linear rate 60ID springs?
Cheers in advance
https://www.sau.com.au/forums/topic/85845-king-whiteline-lovells-springs/
As always, i recall Sydneykid posted on the subject ages ago, i cant recall the exact differences myself, other then the rate of cooling/quenching affects the grain structure after being heated beyond a metals eutectic point (does it get heated that high???) so requires controlled cooling to stop the grain structure from becoming too martensitic and becoming brittle.
Cold working also has dramas, and requires a steel with slightly different mechanical properties, and cold workign normally hardens the metal...so there is a trade off in there as well when the spring will have very high cyclic loads and likely heat up during operation.
LOL...i bet i have confused martensite with austenite etc...i cant remember that crap. i bet GTR_Geoff or someone else knows it off the tops of their heads though
I will avoid the metallurgy. Whitleine use cold winding spring steel from BHP (to the German Standard) , it is specifically designed for the cold winding of coils and to maintain its grain structure during that process. This requires high powered hydraulic coil winders. This the same basic steel specification as used by Eibach, Jamex, Koni, Bilstein etc This process is good if you are making small batch runs, as the set up time for different coils is short.
Kings, on the other hand, use spring steel, also from BHP, that is designed for hot winding. This requires a much lower powered coil winder, but tempering is an additional step in the process. Many OEM coils are made this way as the process is good for long batch runs, due to the longer (than cold winding) set up time.
The bottom line is, neither process is technically superior as long as the procedures (for that grade of spring steel) are followed.
:rolleyes: cheers :)
Thanks Gary,
My other questions was, is there any problem with going to a shorter spring (from 250 to 220mm) if I am using tender coils and have plenty of threaded shock body to wind the lower spring seats up a bit?
cheers, marcus
Thanks Gary,
cheers, marcus
No, just be aware of the increased potential for coil bind and make sure the bump stops prevent it. Coil springs don't like coil bind.
:D cheers ;)
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
