Guys, Ben is focused on making cars go fast and developing them into serious performance cars, mostly based around achieving quick circuit times. If your serious about developing a GTST, then he's still the best guy around and i'm sure he'll be happy to do your work.
At the moment there are a few long time customers doing some pretty serious stuff. So he's a busy man anyway.
Don't bother calling up if you just want a blow off valve fitted and your new boost controller installed. There are plenty of workshops around that can do this type of work for you.
https://www.sau.com.au/forums/topic/85934-racepace-address/#findComment-1559099
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
