My theory is this:
The new turbo has a better bearing cartridge and I know for a fact that it spins way more when you turn the car off, so you would assume that it will spin faster & longer when the clutch is pressed in.
So, with a higher turbo rpm with clutch in combined with the fact that the GT30 comp housing is flowing much more air I am getting compressor surge...
Its either this, or the guys who made my intake piping blocked the BOV return pipe near the mouth of the turbo
What do you guys think?
its not a lot to do with RPM, and little RB25 turbo would spin faster to make 12 psi than a GT30... if my brain is thinking logically
check your BOV, like make sure its working, not just hooked up.
Worst case, just purchase GTR ones.
They work perfectly
Yea, it will vent small amount of pressure like 5psi for example. Its when you get higher presure that it start to flutter.
The GT30 certainly does flow the 12psi much easier... But at the end of the day 12psi measured at the intake plenum is 12psi no matter what turbo you use.
do you get flutter only at 12psi and a normal stock bov sound at say 5psi?
I have another question.
is 12 psi 12 psi?
I mean, 12 psi produced by the stock turbo = the same amount of air as 12 psi from the GT30?
My brain won't bend to work it out today....
well if it can vent at 5 psi but not at the higher 12, then 2 things can be the issue.
1.) the bov can't flow enough.
2.) the return line is too small and can't flow enough to the inlet.
either of those will cause enough of a blockage to cause a fluttering.
Lordsnipe - you're right..
just thought about it now.. when I got an RB25 turbo on my RB20, on the same boost (11psi) it was making a decent amount more power than with stock turbo.
I just can't think of the theory behind it.
if it's 12 psi in the motor, then how does that effect flow wether it's from gt30 or T25...
brain broken..
Sounds like you need a bigger BOV or one that vents better or both.
Does this only happen at high rpm (high flow rates). ie. does it surge if you shift at 4000rpm? Cause that would be a similar flow rate to your stock turbo at 5000rpm (estimate)
As for the does a bigger turbo flow more than a stock turbo with 12psi in the plenum ??
Well it's 12psi in the plenum but the engine makes more power which means it has more flow. (ie. eats more volume of air per second) This is because the turbo is more efficient and uses less exhaust restriciton to make the intake pressure so it lets more air out of the engine for more air to go in.
Got it?
They would flow the similar in the midrange though where the stock turbo is still sort of efficient.
bah 12psi is too low on a gt30r not even on the compressor map........
boost it to 14 then tell us how it goes.
also the stock bov is good for stock turbos but big tubos need some flow for the BPV.
another option would be to run dual bov's to vent boost but at that point the fab work and cost would make it cheaper to buy a highflow bov/bpv
Arr,
That makes sence. I have always wondered how that worked, thanks for clearing it up!
As for my BOV, it seems to have loosened up a little. Now it will vent fine for low boost & low rpm but as soon as you get a little more boost (~10psi) & rpm she goes PSSSHHH flutter flutter flutter :)
Got it?
Does anybody have some pics of a Plumb back installed on a RB25DET???
An aftermarket one I mean...
just try an aftermarket plumback one... if it doesn't flutter at high revs, then you're done.
if it does, then the bov return line would be the restriction.
Edited by GunMetalR33
i had to change my stocky over after gt30 installation , it was leaking at high boost. put a blitz supersound on and it works fine , i have no compressor surge problems. gunmetal ive got pics now to of oil lines and of the turbo actually on my car, if you want i can send you photos, just pm me your email and i will send photos.
Its OK now mate, I have it fitted and sorted. Now I just have the injectors left to do and a tune. At what PSI did your BOV leak? I thought the stock BOV would be fine. Did you get any compressor surge with the old BOV?
Is your Blitz BOV a plumb back and if so do you have any pics of it mounted?
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
