  • Replies 72
Y0 Geoff, I think Michael wants to feed and booze you up tomorrow afternoon/evening?.. if thats all good then just bring the gtr with you and I'll wash it before I do mine :P
Just don't do what I do.. park it near the BBQ when its recently washed :~(
mmmmmm oily gleam.. so pretty!
https://www.sau.com.au/forums/topic/86080-rimjob/page/4/#findComment-1560358
nice colour combination, i'm looking to get a set of wheels for my car does any1 have any suggestions on what tyre dimension  goes well with skylines in 18"
Yes, a set of Nismo LMGT3s would do you well. Want some?
Car looks cool James. No more gutter rashed wheels. Either set looks trick :)
https://www.sau.com.au/forums/topic/86080-rimjob/page/4/#findComment-1561635
Ah, yeah... sorry about that.
I can write you a note to stipulate that it was the previous hack owner and a swift, illegal park outside a fish and chip shop that was at fault :P
Can't wait to see yours with the TEs though - hotness.
https://www.sau.com.au/forums/topic/86080-rimjob/page/4/#findComment-1563907
I can write you a note to stipulate that it was the previous hack owner and a swift, illegal park outside a fish and chip shop that was at fault :D
It's gunna be sweeeeeeeet,,,
the 381mm Harrops are gunna look very snug inside them.
https://www.sau.com.au/forums/topic/86080-rimjob/page/4/#findComment-1565141
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
