OK, well here are a few examples by what i mean in the title..
1) Usually when you are logged in, and you close the window (say u wanted to go have lunch n close the brower).. You come back and open up sau again, you are still logged in.. This does not happen anymore..
2) If someone posts a link to another sau thread, and i click on it, the page im in currently logs me out and so does the page i open.. This enevr use to happen..
Hmm is it just my computer??
This only started today..
Please help, coz its really annoying loggin in all the time..
Thanks. . :)
https://www.sau.com.au/forums/topic/86353-alwys-gettin-logged-out/
  • Replies 63
I tried, deleting all my cookies and starting over. uninstalling all the security software i had, tried it, didnt work, reinstalled it, no change. ran spyware/addware/virus scanners. didnt fx the problem. so I dont think its PC based...
as long as I keep one page open on SAU its ok. but as soon as I open another page and go to SAU it logs me out. if I click on a link and it opens in a new page, it logs me out.
This happened to me, i tell you how i fixed it, i logged into SAU and when it came up to the main menu i hit 'add to favourites' if i keep using this favourites link to open SAU im always logged in, but if i just type in sau.com.au it doesnt work.
Also make sure you click 'remember me' and 'store password to computer'
Dayne
this happend to me the other day and it is definately limited to some pcs. i was using another pc here at work and i kept getting logged out to the point that i couldn't even post. i came back to my pc and it's all good.
YAY its workin now dude. .seems like its fixed it i hope.. hahah..
thanks for that idea man..
cheers..
hahah well not really now..
not workin any longer.. hhmm not happy jan..
mods??
to those ppl who keep getting logged out, does it still happen???
voice up ppl..
so i know its jst my comp or something l
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
