Hey guys, im finally gonna achieve my dream which is to own an R34. Ive seen one that i want and im gonna go get it, but id like some advice first.
THe car is a 98 GTT, done 40,000k's , its stock and i can get it onroad for $35k.
Does this seem reasonable? ive seen the car and it appears in top condition but i want to cover all my bases b4 buying. Then i have to deal with selling my R33 lol.
Any info would help
https://www.sau.com.au/forums/topic/86573-so-im-finally-buying-an-r34/
  • Replies 45
Posted Images
well id say the same as any stock R34...
well imported they range from 27k+ that includes compliance... so lets say you get one for 30k landed and complied... by the time you rego it, pay for the duty to rego it and clean it up its probably better off going for one u can go look at... test drive... get inspected etc.
i reckon you should go for it
well the car is 34900 but the guy wants to get rid of it quickly and its already been complied so on road including rego and stamp duty is $35k, which i think is a pretty good deal.
And it is stock except for the Tein suspension and a few Nismo exterior additions, like indicator covers and i think a Nismo kit, altho im not sure if that kit is stock.
34's rust around the stop light in the bootlid so check for that....look for tape off's around the door apature,window moulds and boot apature for history on refinishing....also look for jaw marks on the sill/floorpan lap join for any history of the car being pulled about on a pulling rack or bench.Check door aparture to inner panel for original spot welds(you will need to slide up the pinch weld to check that)also check the radiator support panel/back panel for original spotwelds and might as well have a good look at the chassis rails/floor for any signs of meddleing...all this stuff is very easy to check without the need of any tools....i have looked at many cars for people checking all these things and within 5 minutes tell wether to look further or to walk....usually the latter!Goodluck!
lol id prob only know where to look for half that stuff, but ill try to check it all out thanx
yep, Troy went over my car like that... and i got the rust around the stop light... but as far as i can remember, didn't have problems with the other stuff ;) Lucky i guess. I imported.
and what troy just put up should be your basic check for ANY car guys not just an R34 (apart from the R34 tail lights bit altho a lot of cars tend to rust around the rear lights as a lot of water gets trapped in those areas running off the boot wells)
you will lose quite a few thousand on it if you hold onto it for a couple of years, as quite a few R34 are now coming into the country right now. In 4 years or so they will be like R33's..
I'd beat him down a few $k
Also, if i buy the car, i apparently get a holiday anywhere in Oz to the value of 3k. I dont really want the holiday and i was thinking to try and get the price of the holiday knocked off the car lol.
Ill do an inspection of the car again when i go down on wed. the only things i noticed when i saw it last was a sort of deep scratch in the top part of the boot on the outside..the car looked good, but i was told it hasnt been cut and polished yet and it will look better, so when thats done it will prob get most of the scratch out, but its not totally removable..that was my only concern, plus some of the steering wheel leather has worn away and u can see the foam underneath.
But apart from those the car is in top condition.
Oh and it has a GTR trim on the inside.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
