Thank you to those who have placed an order
Anyone wishing to pay using credit card or paypal can now purchase heir set online via our website at the URL below
http://www.justjap.com/bridestyleseatspecial.htm
Cheers,
Steve
  • Replies 175
Posted Images
We have some stock available of the black with grey centre, black with red centre and black with blue centre - all of which are ready for immediate pickup or dispatch from our Kirrawee store.
:P
Hi steve,
I put an order in for a pair of the all red seats just wondering when they will be delivered, I am in Melb.
Thanks
Jamie
Hi Jamie, we are waiting the container to arrive which is due in around 3 weeks, once the seats arrive, all pre-orders will be dispatched immediately.
If you have any further questions please dont hesitate to ask
Regards,
Steve
Great service guys I have the seats thanks, now how do I put them in? I was hoping them would come with some sort of instructions, obviously they are designed for professional installation. Anyway I have ripped one of my standard seats out and taken the bits off it that I think I need. However, the mounting brackets are pretty much stuck to the sliding mechanism on the seat. Any suggestions, ideas or is there an online manual somewhere?
mspec, how does the black with grey centre go with the your car - im assuming its white. also are the seats comfortable to sit in, whats the material like.
They look really good for $350 a pair, they also go very well with my interior and yeah my car is white :) Installing them is a bit tricky but I am getting there.
mspec, wouldnt mind posting pics of the seats inside the car would you. i also have a white line and thinking of getting a combo colour other then black and red which seems to have alot pre-sold whilst the combo colour im assuming it already in stock ready to deliver.
haha once I get them in I will post some pics, I will only have time to get one in before the next track day and I'm not even going to bother with the other one just yet. To be honest I found it much easier to install my clutch than these seats :)
Interested in a pair of avail ones. How long does delivery take to WA? So the total cost is $430 ?
Thats correct Keefy
LoL. Err. So what colours are avail now? I want the leaver kind for reclining. Also, how long would it take for delivery to WA? Last thing is how much work is needed to get them fitted onto a R33 ?
Could you please tell me how much for post to Canberra??
$430 delivered
Cheers,
Steve :P
Are compliance plates required for these seats here in QLD?
Or can I just rip out the standard R33 GTS-T seats and fit these with the universal rails that come with it?
Hi mate, you are best to check the regulations in your state in regards to fitting. The seats include universal rails that need to be modified and adapted to your existing rails to bolt in, which usually requires some welding.
We recommend having your seats fitting by a competant workshop.
Cheers,
Steve
Hi steve,
have the seats arrived yet?????
Cheers
Jamie
Hi Jamie, they are on the water as I type, not long now.
Steve
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
