Hey guys,
I am interested in up grading my turbo! I know there is allot of skyline running round with these GT30r or the GT35r! I鈥檓 a big fan of this turbo but allot of people I have talked to that have them there not hitting boost until like 4800rpm and in a gtst you only basically have till 7000rpm! I want a turbo smaller than this that is capable of making 300rwkw if I want but something that will come on boost earlier and chop a skyline with a gt30r!
Any suggestions or info would be appreciated
Cheers
https://www.sau.com.au/forums/topic/86817-turbo-questions/
Grab a VG30 or similiar sized turbine housing, machine it up to suit a GT30 -12 CHRA with a .6 comp cover. + a set of cams and you will get very very close to 300rwkw. That should come on hard just before 4k.
The only way to really drop spool times more is to drop the head on a rb30 block.
https://www.sau.com.au/forums/topic/86817-turbo-questions/#findComment-1568669
I personally think that what you're requesting is stupid.
quick option - NOS
the only way to spin up a big turbo quickly is to have more exhaust gases.
to do this, apart from Nitrous, you need more capacity.
Sure cams will help and timing and tuning and the hey and the hoe..
but using a 3L bottom end as discussed in the 137 page thread up there (points to the top of the forum), you will be able to spin up this turbo with ease.
but you don't seem to have a proper goal in mind.
you jump from 300rwkw to beating an RB25 with the same turbo to having no lag..
so there's probably no helping ya..
Edited by GTST
https://www.sau.com.au/forums/topic/86817-turbo-questions/#findComment-1569085
the current mods i have are turbo back 3.5inch exhaust, fmic, avcr, Gtr fuel pump and a fully rebuilt engine with forged internals could go into detail about the rebuild but wont and my 555cc and pfc are on the way! yer i just want a good turbo and come's on boost early and produce round the 300rwkw! price is not an issue!
Edited by al_r33
https://www.sau.com.au/forums/topic/86817-turbo-questions/#findComment-1569218
price not an issue?
ok do an rb30 bottom end
change and 740cc injectors
change to gt35r
get a suitable external wastegate
get a suitable manifold
4" exhaust
get some suspension work done probably a complete whileline works kit
get some 265 tyres or semi slicks
change to 040 fuel pump
probably want to look at fuel rail too
youll need a bigger airflow meter probably q45
your clutch will get fried as well so change clutch
probably want a good cold air intake with such a larger amount of air coming into the system
dont rev to 7000rpm with the rb30 bottom end more realistic would be 6000rpm as it wont make any more power and will have issues with the harmonic balancer
i am by no means an expert (far from it actually) so you would be better to speak to a tuner and work out a realistic goal
https://www.sau.com.au/forums/topic/86817-turbo-questions/#findComment-1569558
Actually there is a couple of options in the GT30 turbine based range , just maybe not common or cheap .
There is a version of the HKS GT3037 which has a 52 trim compressor rather than the 56 trim comp version which is the same as the GT30R . The 52 trim version comes with a .50 ARR non port shrouded comp cover (housing) instead of the 56 trims .60ARR port shrouded comp cover .
52 trim CHRA no 700177-0006 , turbo no 700382-0009 or -0010
56 trim CHRA no 700177-0007 , turbo no 700382-0011 or -0012
Second option is the propper GT30 turbine version of the GT3071R CHRA no
700177-0023 . This uses the 56 trim GT35 71.1mm comp and has the same compressor flow capacity as the 48 trim version of the HKS GT3037 but with higher efficiency and less innertia to accelerate . The GT37 compressors in 3037's (48/52/56T) and GT30R (56T) are 76mm .
So two options , the 3037 52 trim and the GT3071R generally use the same type of comp cover so appear the same externally .
Your call , cheers A .
Edited by discopotato03
https://www.sau.com.au/forums/topic/86817-turbo-questions/#findComment-1569798
