yes been very busy getting ready for Super Drift
oil cooler and relocator kit
radiator flushed and new top
new gauges
rb24 motor new tomei rings/ 1.2mm gasket / new bearings / 82mm tomei forged pistons
17x8,9 drif teks, running 235/45/17 wanli rear
new uras kit / paint
sparco seat
rear camber arms
rear strut bar
ummm thats off the top of my head anyway :S
fark man im so jealous. I cant even afford a f**king diff :(
What oil cooler did you get ? JustJap ?
running a hks 2530 on it still but got issue's somewhere power seems 'restricted' to around 180-190rwkw !!! :dry: the torque is noticeable but have to sort this out now that i have time :thumbsup:
the 2530 has made 236rwkw on a stock rb20 motor so would've though similar peak power with added low/midrange... hmmm
Heres some pictures of my laufiro as she sits at the moment. I bought the car for 1k in rough as guts condition so i wouldnt have to drive my done up s14 k's to work every day. After a few burnouts and a very cheap rb30, a few blown diffs etc i decided this was my next project.
The pictures shown are when the car still had the rb30e installed with nissan rocker cover, rb20e inlet, injectors and computer. It came out later that day.
Car is sitting in a shed waiting for the engine to be built. (NZ)
Specs when completed (should be about 6/8 months)
rb30det
r32 rb25de head
rb25det (r33 trans) - have rb20det at present but will be upgrading
gt3540r 0.86
tial external wastegate
ecr33 power fc modified to suit
q45 afm
sard 700cc gtr injectors with resistor pack
acl pistons
acl race bearings
gtr head gasket
performance springs valve springs
block decked to give perfect 8.5.1 compression
I have most of the parts together here now, just waiting for my mechanic mate to get the motivation to start the engine build.
17x8.5 30 offset rear Racing Sparco rims
17.8 35 offset front
The body is an 89 cefiro that was as rough as guts when i got it. The laurel front was off a friends parts car and the whole car has been sprayed in my garage. The engine was installed as a friends boss had a cheap one and the rb20e wasnt doing its job spinning tyres.
I pick up some custom laufiro guards in a week or so time so that should complete the exterior. I dont plan on fancy kits etc as they are likely to get damaged and ruin the drivability of the car.
It should be good for 320+ kws when completed
Edited by SirRacer
  • Like 1
sir racer were can i get some of those lofiro gards can you please post a pick of those because im looking at doing a lofiro convertion aswell
they were custom made by someone in auckland nz by combining both cefiro and laurel guards together. apparently its a shit of a job so will cost around 600+ easily
i have thought about getting a fibreglass copy made but dont really want to fork out 400 to get them copied then loose my individuality. im in NZ anyway so that prohibits you getting a copy of mine
Thanks yeah I love it more than anything :dry: All work carried out in Japan.. Fronts are aftermarket flares that have been smoothed over. I'm guessing the rears are the same with the added complication of the door.. but yes large quantities of bog is involved :)
Edited by Drift_Limo
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
