  • 3 weeks later...
Nah they're not origin, 01 have spokes that curve at the ends like TE37's and 02's have spokes that run flush with the lip. Those have spokes that run into the dishy area.
What about DNA 02?
https://www.google.com.au/search?q=origin+dnA+02&rlz=1C1CHMO_en-GBAU554AU554&espv=210&es_sm=122&source=lnms&tbm=isch&sa=X&ei=pFGsUqv-G6SziAeykIHYBQ&ved=0CAcQ_AUoAQ&biw=1097&bih=545
Nah Kris is right, and they are definitely 6 spoke.
Some come with more concave than others though it seems, probably is a couple of different models or something. Hard to find info.
Older pic here.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
