Had lunch had a great little joint in Hampton on Hampton St.
Bit of a Bar-B!!! Shop 4/427 Hampton St, Hampton.
Choice of Beef, Lamb, Chicken, Pork, the sphincter of the universe, Sausage, Fish, Prawns etc
Basically you tell em what meat you want and what type of roll... he bar-bs it up for ya and you help yourself to the veges/salads/sauces to put in it.
the meat is absolutley cooked to perfection and the damper rolls are awesome.
Highly recommend it if your in the area!
And for the more adventurous you can have Croc or Kanga.
I just ate a Lamb and then a Beef damper.... 9/10
https://www.sau.com.au/forums/topic/87089-inarks-new-recommended-eats/
n e 1 been to lazy moes. if anyone finishes the meat platter you get the next one for free. the plate is huge and you get a wet towel and a bowl to put ure bones in,
there are sausages, lamb, paddies, egg, ribs, steak, all on a huge pile of chips.
there is some more meats but cant remember them all
good luck trying to finish it all
cyas
Were is this so called lazy moes ? and is the food any good or is that bad thats why ppl dont finish it  :lol:
One of our family friends owns the Lazy Moe's chain:
Lazy Moe's
320 Canterbury Rd Forest Hill 3131 (03) 9878 5400
Lazy Moe's
90- 94 Warrigal Rd Oakleigh 3166 (03) 9563 0888
Lazy Moe's
161 Mickleham Rd Tullamarine 3043 (03) 9335 1666
must try this place
and also interested in the lazy moes, driven past one a few times and an sign of interested glitted in the corner of my eye as well as a stain of drool falling forming on my tshirt.
DAMN THAT SOUNDS REAL GOOD!!!!!!!!!!!!!!! MIGHT HAVE TO GO AN CHECK IT OUT :)
has anyone been to Maxy's in Glenhuntly Road Elsternwick
(just down from Elsternwick Station)
If you like your meat bbq'd with heaps of bbq sauce, this is the place for you. Looks expensive, but most of the main courses will feed 2 people easily
Where abouts is Hampton? Im a fan of Bbqed meat so I have to pay a visit.
As for Lazy moes, I went there once agesssss ago for a dinner after my Work training and the size of there servings are like as big a 4 meals in a posh little inner city restaurant.
The meat platters called Mixed grill - and one of my colleagues, whos nearly 7 foot tall and with a appetite to match cudnt even eat 3/4s of it, it had eggs ,sausages, steak, pork chops, a rack of ribs, burgers, a mountain of chips. It even had a lamp full of barbeque sauce. One thing I can say, for so much food, it tastes awesome!I had a photo of it on my fone because I cudnt beleive how huge it was- all there meals were super super huge!
Itd be good to share, however when u go there, guarenteed ull be so hungry u wudnt wanna share.
Hampton St runs off of Nepean Hwy at Meneres BMW. Just follow it for a little way until you hit the main st.
Oh and if anyone likes Charcoal Chicken. The absolute best one IMO is the one on Glenhuntly Rd just near the train line up near the intersection of Grange Road. Have had a few others and none get close to this one. Damn now I want one at 9am! :D
Theres also a good one on center road... right near the post office in east bentleigh.
oh and the quickest way to the BBQ joint is go all the way up nepean (from the city) til u get to southland and turn right down whatever rd that servo is on on the corner and follow it all the way down til u hit hampton road and turn right... tis like 500m down on the left
Thats Bay Rd with the Jet Fuel servo on the corner. B)
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
