Hey all,
On my way to exam today and was pacing myself. I hit boost and weaved through some cars (SAFELY) to suddenly notice a cop pointing a radar at me. I don't know what speed I was doing, but i get the feeling I was a little bit over by the time he would have read my speed.
I wasn't pulled over or anything, does that mean I got away with it, or does it mean that I will get a ticket in the mail sometime soon?
Any past experiences or knowledge would be much appreciated so I don't have this cloud hanging over my head all weekend.
Kind Regards,
Joel
Edited by leb
https://www.sau.com.au/forums/topic/87157-speeding/
Hey all,
Kind Regards,
Joel
I had an unfortunate experience when i was travelling along a main road:
Came out of a long slip way and could see that traffic was coming so I thought may as well speed up a bit... was doing 75 or so as I came onto the main road and as I continued up traffic slowed - and then I noticed the fagman in blue holding something.
It was a 2 lane road - some traffic was told to keep on going, where as I was pulled over to the side and told that i'd been doing a substancial amount over the limit.
Fine was written out to me then and there...
Worst part was 3 demerit points:(
So there ya go.
https://www.sau.com.au/forums/topic/87157-speeding/#findComment-1574198
Sometimes they don't bother if it's only a bit over but if it was a hand held they have to pull you.
Sometimes they have mounted in cars or on the side of the road that will take photos.. If it was on a tripod or mounted in dash then you'll usually see a flash.
https://www.sau.com.au/forums/topic/87157-speeding/#findComment-1577660
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
